Question about Konica Minolta Bizhub 222 Black and White Copier
Code m2 error - Konica Minolta Bizhub 222 Black and White Copier
How to remove error code M2
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
Jun 06, 2015 | Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
Stop work with error m2
clear the counters first then replace the drum and developer then run F8
Feb 22, 2014 | Konica Minolta Office Equipment & Supplies
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
MY PROBLEM IS ERROR CODE M2 PL SOLUTION
Here is a website that has a list of Sharp Error Codes
Also here is a list of the drivers and copies of the
Sharp AR-M-205 owners manual and drivers
Hope this helps
Nov 30, 2012 | Sharp AR-M205 Copier
Error M2
You did not let us know the secret of what make and mode of machine you have..... I'm going to take a SWAG..... You have a Minolta or panasonic copier???? M2 is for a PM counter
Nov 07, 2012 | Office Equipment & Supplies
Konica Minolta Bizhub 222 Black and White Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
