Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
There is a bad odor blowing out from under my Whirlpool side-by-side refigerator. How do I fix it?
  • graham1607 May 20, 2009
    It's definitely not inside the unit... the bad odor is coming from outside and under the unit. I've cleaned the from vent which helped a bit. But I can't seem remove the pan.
    Brigadier General:
  • 8,619 Answers
Hi
Odors in the refrigerator can come from many different sources. Spoiling food, spilled milk, open food. Often a really good cleaning out with an ammonia cleaner can help or with a baking soda water mixture.
But, sometimes an odor can "permeate" into one of the plastic parts found inside the fridge, crisper pans, door liners, shelf supports. Even after you have found the spoiling food, removed it, cleaned the fridge up.....sometimes another plastic part will pick up this odor and continue to give the odor back off. A few things that can help with this type of an odor, place one these inside the fridge section:
- box of baking soda
- dish of coffee grounds
- open slices of bread
The bread trick can be used to effectively to remove odors. Just throw a slice or two onto one of the shelves in the fresh food compartment, leave the bread slice(s) in there for 12-24 hours -no longer- and then throw the bread out or I throw the bread outside for the birds to eat. When bread goes stall, it will **** in odors very well. Because the air inside the refrigerator is blown between both sections, this will help the fridge and freezer sections. Do this for about a week and you should notice a big change in the odor problem :-)
A really bad odor problem. Sometimes something like milk or juice is spilled inside the fridge. The liquid can run under the plastic edge breakers and get into the insulation. This can be very difficult to clean and may require a service call to have the old insulation removed and replaced with new insulation in that section.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 20, 2009
  • Rylee Smith
    Rylee Smith May 20, 2009
    Please check if there is some thing rotten near the compressor. Also check for the fan and frost at the back of the refrigerater.
    Thanks
    Rylee
    Scholar:
  • 42 Answers
At some point something was spilled in the refrigerator. I'm sure it has been cleaned up now, but some of that 'stuff' (milk is the usual culprit) has found its way to the pan underneath the refrigerator. This pan is part of the refrigerator and was there when you bought the unit, so it is nothing that you put there..
The pan under the 'fridge is to collect spilled liquids so that they don't accumulate on the floor. It will be a fiberglass or plastic pan.
I'm not sure where the pan is on your unit --- most times it is accessable at the floor level from the front of the unit. You may have to remove a grille-like piece from the front first.
That grille- like piece should be made to pop off because cleaning the pan is a consumer maintenance item.
Remove the pan carefully so as not to spill any liquids that may still be sloshing around in the pan, and hose it down in the back yard.
Once you are done cleaning the pan (both sides please) wipe it down with a little vinegar. You can rinse off the vinegar and then dry it thoroughly before you re-install it. The vinegar will kill any mold that may be growing in the pan.
good luck!!
Bad smell in Refrigerator and cleaned it throughly and it still stinks. Strange since it will get worse then better for no reason. I cannot find a drain in this side by side. If anyone has any ideas please...
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look in the drain pan to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first.
Jan 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a Kenmore model 106.5702602 side-by-side for 1 year and can't get rid of freezer odor...have tried everything and can't put anything in freezer that isn't affected by this smell. Help!
the air blows from freezer to fridge side and then returns from fridge to freezer,so it could be and usually is something on fridge side causing odors or funny tasting ice cubes,check under bottom draws on fridge side,what kind of odor is it?
Nov 28, 2009 | Kenmore Refrigerators
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side 4yrs old has smelly odor coming from under fridge. was very dusty but didn't see anything else.
If you just vacuumed the dust out from under the fridge , give it a few days , so the fan will pull any odor left on the previously dirty coils , out .
Sep 17, 2009 | Refrigerators
Water is leaking really badly underneath my Whirlpool refigerator.
I had this problem. Check you water line leading to your ice maker. the plastic section of it running up into the freezer cracks and leaks. easy fix, replace the tubing if it's leaking.
Jul 12, 2009 | Whirlpool Refrigerators
Whirlpool Side by Side Refigerator won't engage ice dispenser.
Could be that the auger in the ice bucket is obstructed or broken, or the auger motor is bad.
Nov 02, 2017 | Whirlpool GC5SHEXNS Side by Side...
Odor
Try taking your fresh perked coffee grounds, put them in a bowl and set them in the refigerator side. Change daily and do this 4 or 5 times.
Jul 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
357 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
