Question about Car Audio & Video
No sound from car radio or cd changer in my bmw 740. changed tuners still only perodic sound
  • chuckcarrbro May 21, 2009
    Did not find a 3 amp fuse at all. Can you give me more info on the location of this fuse? I am currently looking in the fuse box located on the oposite side of the cd changer.
  • chuckcarrbro May 25, 2009
    Getting perodic sound out of my car radio. changed out tuners and still perodic or no sound. BMW 740.
  • 230 Answers
The problem is likely with the amplifier, this is located in the rear fender. I've never personly changed one of these but the instructions on how to do it on this site should come in handy:
http://www.bimmerwerkz.com/forum/audio-electronics/how-do-you-remove-factory-amplifier-62289.html
The amplifier may be repaired through a local repair shop, it sounds like it's suffering from dry/cracked solder joints.
Hope this is what your after.
Cheers
Posted on May 25, 2009
    Sergeant:
    Champion:
  • 219 Answers
Hi, i had the same problem
here my findings that solved my issue:
  1. disconnect the 3 Amp (not 30 A) fuse labeled N° 72. it is the first in the row, located on the right side of the boot (opposite side of the DVD player)
  2. clean the contacts (use a knife to get the oxidation off making the metal shining),
  3. then put the fuse back.
This solved my issue. I haven't touched to the AMP and Radio connectors.
Thanks!
Sandy
Posted on May 20, 2009
  • Sandeep Gupta May 21, 2009
    well frnd if u r not able to find the location of the fuse then u need to take the help of some mechanic as i have clearly provided the loaction of fuse.
    As it would be a better way of fixing ur problem
    Thanks!
    Sandy
The built in sat nav screen keeps going up and down without switching on and also the radio cd does not switch on. any advise would be appreciated
bmw navigation radio cd changer repair
www.hitechserv.com/electronics-repair/oem-navigation-dvd-cd.../67
We repair all models of BMW GPS CD Changer Stereo ... shows on the screen, no audio, display shows no navigation disc but there is a disc inside, do not play CD. ... If there is sound but your blue tooth or satellte tuner is not working "if your car is equipped with blue ..... The MK3, MK4 computers has a GPS module built in.
3 Series (E46) built-in Sat Navs - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=862860
PistonHeadsJun 9, 2010 - I don't know much about the OEM sat navs, other than that they cost no less than ... would need to be re-positioned and CD player becomes redundant. ... on forums, they do the job, just about and sometimes not too well at all.
Nov 01, 2015 | Cars & Trucks
My radio works but when i put on the cd changer it plays but no sound
Are you using an amplifier? If you are, it sounds like you are using the power antenna remote turn on (usually blue) instead of the amplifier remote turn on (usually blue/white). Leaving tuner mode when using the power antenna remote turn on turns the amplifier off.
Feb 21, 2013 | Car Audio & Video
1998 7 Series: MY 1998 BMW 740 IL HAS NO SOUND FROM THE C.D. PLAY...
CD Changer needs to be replaced... You can buy one online from Ebay. Make sure you have the correct model...
May 16, 2010 | 1998 BMW 7 Series
Fitting a cd changer to a P reg ford fiesta radio
Buy a CD changer with FM tuner. All brands have at least one model.
Sep 19, 2009 | Car Audio & Video
Radio and cd changer for bmw m3 e36 ea88906
If you go to www.crutchfield.com they will have a menu for all upgrades to your vehicles sound system including which head units (or stereos) will fit your Bimmer.
~Stillin~
May 21, 2009 | 1994 BMW 3 Series
Would like to put the original CD changer/player
To put the original back in just hope the harness behind the radio wasant cut into. If its not it should just plug right in and mount back up in the stock location.
as far as the cd changer. if you would want to add one. you would need to find the changer, harness and headunit from a model with one.
May 19, 2009 | 2008 BMW 528i Sedan
Is it possible: change cd changer input to ipod input
I'm afraid not. The best advice I can give you is to get a Radio Tuner Adapter for your I-pod. Most prople will tell you to use a Cassette adapter, and this is fine. However it sounds like you want the best sound you can get from your I-pod. The tuner adapter is the way to get it. You will get a better sound frequency range from your factory tuner than your cassette. The factory Head unit in your Sable isn't bad, just changing the factory speakers will make a huge diffrence. Good Luck, and don't forget to vote.
Jan 26, 2009 | 1998 Mercury Sable
Cd changer
Look in the back where the cd changer used to be if there are any loose wires make sure that they are not touching, If there arent any wires touching, Check the fuse box and see if the radio fuse has blown.
Jun 05, 2008 | 1997 BMW 328
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
