Question about Senco SCN45 Coil Nailer, Contact or Sequential Actuation
Trigger Fires nails when trigger is pulled what adjustment can I make for it to operate only when pressed against work project?
  • 885 Answers
There is no adjustment that can be made to make the safety work or not. When new, the SCN45 had a safety system that prevents the nailer from firing unless it was pressed against a surface. If your gun fires without the safety being compressed, it has somehow been bypassed either by being jambed or tied in the firing position or the trigger lever is wedged so it can't operate properly. Below is a site that has a great breakdown of your tool that you can reference to see what parts may be missing. This is an older tool and many parts are no longer available.
Senco SCN45 Coil Nailer Parts
Posted on Jul 17, 2014
Gun fires 2 or 3 naiks everytime I pull trigger
Most nailers have two types of triggers available. One is a bump fire and the second is single shot that is activated by releasing the trigger, placing the contact foot against the work, then depress trigger. Bump fire trigger May fire two nails if you place then depress. Check your parts manual to determine which trigger is installed. (Some brands have built-in switch to activate bump) good luck
Jul 13, 2015 | Air Tools & Compressors
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
My bostitch N88RH is not firing nails
May occur when headvalve or driver is stuck (will usually make a pop or click when tigger is depressed), or tigger valve has failed or safety not actually touching trigger firing pin. Easy test, remove nails, remove trigger by pushing out 3mm roll pin or bolt to expose the firing pin. Pull back nail feeder and place the nose against piece of wood ~ depress trigger with very quick motion with finger. If it fires, reinstall trigger and adjust safety foot so that the firing pin is pushed all the way in. If does not fire, replace trigger valve (usually tva6) or remove trigger valve and replace the 3 orings on the inner plunger. If you hear a pop or click when you do test above, remove head and lube the headvalve orings with white grease or silicone paste.
Nov 17, 2011 | Stanley Bostitch N88rh Framing Nailer...
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
GUN DOES NOT FIRE FOR SEVERAL ATTEMPTS--even though gun is pressed firm against work---just had unit serviced and trigger valve replaced-----any suggestions? thanks joel
Remove nails and remove trigger to expose trigger valve pin. Place nose of gun against rubber pad or old coiled up air hose to absorb impact of driver and with very quick and deliberate motion press in trigger pin. If gun fires, then problem is with safety foot not pushing trigger pin all the way in (or worn trigger). Make adjustment as needed or replace faulty parts. If gun still does not fire, then likely problem is with headvalve. If headvalve orings are leaking, gun will not fire. Test for leaking orings as follows. Remove head and remove headvalve, apply silicone paste lube (plenty) to all orings and where orings contact. Assemble and do test above. If gun fires then surface where orings contact is allowing air to leak(smooth with very fine sandpaper if scratched).
Mar 13, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
As you pull the trigger slowly the tool cycles several times
It sounds like you have a contact trip trigger that you are trying to operate as a sequential trip. Sequential trip is when you have to put the tool against the work and pull the trigger every time, contact trip is when you pull the trigger and tap the nailer on the work and it fires. If you operate a contact trip like a sequential it will fire but it usually fire more than one nail. Your instruction manual will explain this, sometimes they give you two seperate triggers for the two modes or there is an adjustment on the nailer.
Aug 03, 2009 | Stanley Air Tools & Compressors
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Senco SCN45 Coil Nailer, Contact or Sequential Actuation Logo
57 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
