Question about Uniden BC340CRS Base Scanner
Uniden troubleshooting had great volume for 1 week now the volume is real low even with it turned all the way up scanner is only 2 weeks old
2 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: i have a uniden bc340crs
This is how you control the back light display on your scanner.
SNOOZE/Backlight - Backlight: Tap the snooze button to turn the LCD backlight on for 15 seconds. Press and hold to permanently turn on the backlight. Press and hold again to turn off the backlight.
Here is a link to the users manual as well. http://www.uniden.com/pdf/bc340crsom.pdf
Posted on Mar 17, 2011
I have a uniden bc340crs scanner that is 1 yr old. my backlit window does not display any of the info for my scanner. i want to reprogram and the 2-9-hold thing does not work even after trying ronnie...
Mar 14, 2011 | Uniden BC340CRS Base Scanner
Why does the uniden bearcat 210LXT have low volume. When turned full blast you can hardly hear it. Is there something we can do?
Your scanner is about 30 years old, so the electronics are old and tired. The problem could be in the audio circuit, the volume "pot' control, or the speaker, but bear in mind that repairing this veteran will likely exceed the cost of a comparable new scanner. Depending on what the actual problem is, connecting an external speaker or headsets to the external speaker jack on the back of the scanner may extend its life.
Bill B
Sep 16, 2010 | Uniden Radio Communications
I have a Bearcat BC 140 scanner that has 2 issues
You have a power supply problem. Lag on start up with low audio. Send it to the factory for repair.
May 01, 2010 | Uniden Radio Communications
When not turned on for a few weeks, looses its memory
Yep, keep the rechargeable battery recharged every two weeks, even when not in use these old NiCad batteries lose their charge.
Oct 17, 2009 | Uniden Radio Communications
Uniden PowerMax 5.8 no audio transmission on two of three remotes
If phone is more than 1 yr. old, battery needs to be replaced, if not reset base by disconnecting power, pressing and holding delete key while reconnecting power.
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
BC895xlt faceplate
ive got a call into uniden direct.com and they are checking..chia
Jan 10, 2008 | Radio Communications
Radio scanner manual
Here is a direct link to the pdf format owners manual for our scanner:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Dean
Rollin CBs
Dec 25, 2007 | Radio Communications
Kenwood ps 150
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage is not dropping too low, you may have a defective speaker or a short in the wiring. Check the resistance of each individual voice coil to make sure all are near the rated impedance.
Dec 01, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Uniden BC340CRS Base Scanner Logo
24 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
