Question about Lands Phones
The phones keypad lights up and i have just brought a new battery and charger for the item but the screen doesnt light up when you turn it on
    Scholar:
  • 155 Answers
Its because the voltage supllied by the chareger is not enough
try using recommended charger
Posted on Jun 04, 2009
When i try to turn on my slvr the keypad will light up for a few seconds then turn off...I tried taking out the battery and replacing it wit a brand new 1 without any luck. I also tried just pluging it...
Hi, problem can be solved.
What causes the keypad will light up for a few seconds then turns off, is because the keypad has a separate function from the phone. (it has a removable keypad). And the keypad inside the cell phone is getting Bad and it needs to be replaced.
You can know how to disassemble the cell phone through the link below:
http://www.formymobile.co.uk/l7disassembly.php
When you replace the keypad,phone will be ok again.
Thanks for using fixya...
Feb 14, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Phone functions fine, but screen is dark. keypad lights, no light above, result of drop :(
it sounds like the screen wire has came loose. try to remove the battery with the phone on. wait 30 seconds and then replace the battery and power it on. the screen should come back. if it doesnt you can use the insurance if you have it, if not you can go to a cell repair shop. usually they are super cheap, if they arnt i would get a new phone.
Jan 03, 2011 | LG VX8300 Cellular Phone
Its shows red flashing light n not turn on
Sounds like either one of 2 problems. 1. The batter is dead and needs replacing (this would explain why the charger isn't doing anything. 2. The phone requires a software re-flash which would have to be carried out by sony erricsson themselves. It might be worth trying a new battery first however. Hope this helps :o)
Aug 31, 2009 | Sony Ericsson K550i Cellular Phone
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Screen and keypad.
well, there is no much to do in there, either the charger, the battery , or the phone is dead.
Try removing battery from inside and then put everything back, and try restarting it again, after charging for ten minutes.
If it still does not work, and the phone is new, call the number on the phone booklet, and ask if you can take your new phone to an authorized shop for a checkup, if it is a faulty charger or battery, they usually replace them on the spot.
Dec 27, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Razr 3Vc freeze up
the phone firmware need to be reflash to correct this issue you will need to take the phone to a mobile service center to hvae this done.
Nov 23, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3c freeze up
take the phone and have the firmware reflash to correct these issues
Nov 18, 2008 | Motorola Mobility RAZR V3
Cingular 8525
Once you drop a phone in water if the battery is plugged in it will short circuit all the links that the water touches. It is quite possible that it is only the screen not working. But my guess is that the phone is a goner. You may want to search ebay or craigslist for a replacement as your model of phone will have a water damage indicator installed.
Mar 06, 2008 | Motorola Mobility RAZR V3
Motorola v3
look take the battery out and let it sit over night and then u put the battery back in the phone and then put it on the charger when it finish charging cut it on it should work
Aug 11, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
