No power I disconnected the power adapter and power cord. Now that it is re-connected, printer has no power
    Master:
    Sergeant:
  • 461 Answers
Have you turn the switch on?
Posted on May 20, 2009
  • 822 Answers
Pls check your cord if there is AC output and your dc power jack.
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
I have a HP Deskjet D1560, and with the power cord plugged into a working outlet (I checked), the printer won't turn on. Is it just old? Is something wrong with the power cord or the printer?
There is only one way to find out if it is an issue with the printer or the Power cord.
Regards,
Shawn
May 07, 2011 | HP D1560 Deskjet Printer InkJet
I have an HP Photosmart c4795 printer and it has a mind of its own. There is an error code (?) of 824C1300 on the printer screen. Help
Hello rcassity. The error code you are receiving likely is the result of a problem with the printer's power adapter. Be sure to double check that the power adapter connected to the printer is the proper one and that the Voltage of the printer matches that listed on the cord. You can also try resetting the printer's power by following a few quick steps: Start by unplugging the power cord from the printer and then from the wall so that no charge is going through it. If the power cord connects into a power module (resembles a block) separate the cord from the module. After waiting for 15-20 seconds reconnect the cord to the power module. Then plug the power cord directly into the wall outlet. Continue by connecting the power cord to the printer.
Lastly, press and release the printer's ON/POWER button to power the printer back on. Be sure not to hold the power button down.
I hope this helps! Be sure to reply if this has not completely resolved your issue.
Feb 28, 2011 | HP Office Equipment & Supplies
5500
This error message indicates that a problem occurred with the scanner. To resolve this error condition, do the following:
  1. Turn off the printer, then disconnect the power cord.
  2. Wait 30 seconds, then connect the power cord.
  3. Turn on the printer.
May 13, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
70 people viewed this question
k24674
