Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Coffe/water dripping from handle when preparing coffee
This happens sometimes, especially when I put enough coffe in the handle. How do I know exactly how much coffee should i put, and how much should I twist/turn the handle to the roght after I put it?
    President:
  • 1,618 Answers
On the inside of the basket is a line or ridge close to the top, that is your fill line. If you fill the basket to the top and tamp to that line then that should be perfect. For the portafilter it should be no more than a 90° angle with machine if it goes father then it is time to change the group gasket.
Posted on May 20, 2009
My Solis Master 5000 will not make a cup of coffee anymore. I already descaled, the water comes through the steam arm, but not through the coffee drip. How to fix?
If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
Aug 31, 2017 | Solis Coffee Makers & Espresso Machines
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
Water not flowing freely. Coffee only dripping out. Not free flowing like it was a few weeks ago.
big red
your coffe maker has to be cleaned by having it it run normally but put in vinegar instead of water it should cleare it right up
Oct 23, 2009 | Rancilio Silvia Espresso Machine
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee is cold and not brewed properly. Unit has been cleaned,de-calcified, rinsed, but still the coffe is cold. temperature is set to high, and the machine can produce steam. Anyone help?
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 02, 2009 | Gaggia Titanium Espresso Machine
My kitchenaid artisan coffee machine not enough water
if you have water out brewing without handle with coffee, than you check this 3 things:
  1. how fine is grinded the coffe, is it too fine for your machine?
  2. does pump make enough pressure to brew your coffee(you can measure if you attach an gauge to handle or steam pipe.
  3. by any chance your boiler security valve opens too soon and dont let pump to get the needed pressure. (perfect pressure is from 7 to 9 bar)
Mar 31, 2009 | KitchenAid Artisan
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Feb 11, 2008 | Gaggia Titanium Espresso Machine
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
197 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
