Question about Maytag Dishwashers
Knife handle is melted on dishwasher element - Maytag Dishwashers
4 Suggested Answers
SOURCE: plastic melted on Dishwasher heating element
you can also use blow dryer to heat up plastic
Posted on Feb 04, 2009
  • 127 Answers
SOURCE: Knife touching heating element in water, began smoking
a complete model number will help immensely, please...
unless the knife cut through the outer shell/covering of the heater element, or melted to it the worst its gonna do is be really hot..
disconnect from power and remove the kick panel below the door and see if you can move the main motors splash shield with your finger, if not motors seized..
if so motor could still have a burnt winding, but you'll need a multimeter to test it..
good luck, have fun,
thanks,
chuck
Posted on Feb 25, 2010
allbrands
  • 600 Answers
SOURCE: A spoon will a plastic handle melted on the
Hello, Thank You for using FixYa. I will be helping you today. Yes i would remove as much as you can you wont damage the heating element. Then run a cycle with heated dry and check after the cycle if you can remove the fest.
Thank You and please rate my answer if it was helpful..
Posted on Jun 23, 2011
Bosch she56c02uc dishwasher does not cycle, stuck on wash
If the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here The problem is that the circuit board copper is not heavy enough to handle the heating element current, causing the copper to heat and melt the solder connection. A better solution is to solder a short length of copper wire between the two pins to provide more copper and reduce the chance of heating as shown in the attached photo.
Nov 11, 2013 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch dishwasher time delay problems
Bosch Dishwasher Repair
When the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here
Jan 11, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
A spoon will a plastic handle melted on the circular heating element on the floor of the dishwasher. It is stuck on there, should we pry it off? Will the dishwasher still work? What do you suggest?
Jun 22, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
Melted a spoon on element. What can I do to remove plastic on element
The way to remove it is you need to raise the temprature of the element to the level when the spoon melted, not so easy of a task, but nothing else will do it.
I would fire the element, and be ready with a damp terry cloth towel, and wipe the spoon free. Another way would be to use a propane torch, but you MUST protect everything around the element or you will cause more damage.
The key is that you have to acheive the same temprature that melted the spoon, and it will release and leave little, if any residue..
Feb 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Maytag built in dishwasher quiet series 200. Door closed and latch won't release to open door.
insert flat head screwdriver in side of handle and pry out or use dinner knife(butter knife)
Aug 13, 2010 | Dishwashers
The problem you have is that with the heating element energized with 120 volts to heat the water and came in contact with metal and in water, it may have shorted the element out. It may have just tripped the circuit breaker also. Go to the breaker box and you will find the breaker. It is probably in the midway position. Shut it off hard and back on. It should be fine then. Let me know if that was the problem, and if not we will go from there.
Sincerely,
Shastalaker7
Feb 25, 2010 | KitchenAid Dishwashers
The cycle did not complete,the bottom spray arm (the tip) melted along with some plastic utensils (knife handles). Water come out of thee front door.When starting the washer again, the top and bottom spays...
The handles slipped down keeping the spray arm from rotating thus causing it to rest against the heating element. It won't wash because of the hole in the bottom spray arm. You have to replace the spray arm before nything else can be determined.
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Dec 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Lid melted on bottom heating unit -
I just took a knife adn scraped off the heaviest and ran the dishwasher again. When it was complete I scraped some more while it was soft. Most of the plastic is gone now.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
109 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
