Question about LG Verizon Wireless CePhone Vn251 Vn 251 Cosmos 2 Phone. No Contract Required in Original Box Works on Verizon Wireless or Page Plus Network Only
Master code - LG Verizon Wireless CePhone Vn251 Vn 251 Cosmos 2 Phone. No Contract Required in Original Box Works on Verizon Wireless or Page Plus Network Only
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
Master code nokia 105 357267058269766
try this
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 357267058269766 --
Your Nokia Master Code: 7747353212
Jun 20, 2014 | Nokia 2626 Mobile Phone
My IME No. is 355249036519241 Security code forgot
you forget the security code means get the master reset codefor that one, master unlock code is a code that completely resets your phone, removing any securitly locks , get the code my hand set name lava arco3
Jun 13, 2011 | Nokia 6600
L lost my security codes
Get the Master reset Code from the service provider and Unlock it.
Nov 11, 2010 | Nokia 1100
Master code for nokia 1280 with IMEI: 351524/04/635056/1
For the master reset code for your Nokia model mobile,
you can visit this site http://www.prounlocking.com/nokia-dct-master-code-service/rs8wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones........
Oct 08, 2010 | Nokia 1208 Cellular Phone
Master reset code master clear code
You may try default phone and security code to remove restrictions
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
ur defalt phones codes is 12345 or 00000 u can use it
type *#06# on your phone to get it.
Sep 03, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 1200 master code
I need a nokia 1200 master code the imei is 353529026243312
Dec 04, 2009 | Nokia 1100
I want master code of my nokia 1200 imei 356421026610863
IMEI 356421026610863 Master Code 6665754443
Oct 11, 2009 | Nokia 1100
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
Feb 19, 2009 | Motorola Mobility RAZR V3
LG Verizon Wireless CePhone Vn251 Vn 251 Cosmos 2 Phone. No Contract Required in Original Box Works on Verizon Wireless or Page Plus Network Only Logo
52 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
