Question about Toshiba Office Equipment & Supplies
Blue screen saying "Can not start application" and it will not do anything. Re-set's don't work. Connections all okay.
Toshiba copier/fax/scanner/printer - eStudio 202L - initially it was printing pages in an odd fashion - it would take one part of the page and print it on an odd part of the page so the printed pages were jumbled. we shut the machine off to do a re-set and when we turned it back on it just says "Cannot Start Application" and it will not do anything. we have checked all connections and have tried a hard re-set ...no change.
    Champion:
    New Friend:
  • Toshiba Expert
  • 253 Answers
Reinstall firmwear
Posted on Nov 11, 2017
  • 390 Answers
SOURCE: 9800 won't print
turn the cheeky thing off, unplug it, all cables, replug it. Try again once back on. Did it work? If not, try uninstalling it and reinstalling it. Good luck
Posted on Aug 30, 2007
SOURCE: Epson Stylus cx6600 printer not printing
my software cd got lost and i got a new computer so what can I do to install the Epson cx4400 software???
Posted on Jun 21, 2008
SOURCE: Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Posted on Nov 12, 2008
rockitman187
  • 2559 Answers
SOURCE: Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
rudyda3rd
SOURCE: when i upen chrome, keep getting message "the application failed
1) right click on the google chrome icon on your desktop
2) click on properties
3) click on shortcut
4) where it says target and the end put a space and then --no-sandbox
5) press apply and then ok and it should work
if this does not work i am sorry but this is what worked for me
Posted on Mar 19, 2009
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Blue screen only
look first for the source or input button on the remote that changes between the various connections for signal the set has.
Apr 17, 2012 | Televison & Video
I have a problem with my toshiba laptop?i think i need to reset it?can u help me?
Here's how you can restore your Toshiba laptop to factory settings (don't forget to backup your files before restoring it to factory settings).
Restart your pc and even before you see anything on the screen, repeatedly tap on the F8 key until the Advanced Boot Option Screen appears.
Click "Repair Your Computer" if you are not already on it and then press enter.
Choose your country and click ok.
On the System Recovery Options Screen click Restore Application.
Follow the on-screen instructions
When prompted, click on Full Factory Recovery then click on next then yes.
You will notice for a while it seems like nothing is happening, give it some time.
After some minutes, recovery will complete and you click Finish.
Jul 20, 2011 | Computers & Internet
My toshiba laptop starts up and goes to the first page where it says toshiba innovations along the middle of the screen. then it goes to a black screen and in a blue box in the center it asks for a...
There is a known issue on this model and Toshiba knows about it. A password can be automatically be set by the computer and will need to be removed and have the BIOS updated so it won't happen again by an "authorized service provider." You can locate your closest Toshiba ASP at support.toshiba.com This is a known issue and Toshiba knows about it. You should get this covered at no charge if you take it into an ASP, make sure to verify this with the ASP and take it somewhere else if they tell you it will cost you anything. Toshiba will cover this till December 31st 2010.
Toshiba Customer Service # is 1-800-457-7777
Nov 14, 2009 | Toshiba Satellite A215-S4747 Notebook
I just connected my new Kworld PC/TV converter. My tv now displays large vertical color lines. I,ve connected the yellow video cable, s-video cable and the red/green/blue cable. I have a new Toshiba...
Hi and welcome to FixYa,
Initially, a couple of checks:
  • verify that the P/N switch is set to the color system of your country. N (NTSC) for US and P for most of Euroope and Australia;
  • depending on how "old" the TV, the Screen Resolution of the Toshiba may have to be brought down to the lowest possible setting;
  • additionally, the Screen Refresh Rate may likewise need to be lowered say 60 Hz;
  • all of the connections you mentioned are video connections. However, only 1 should be used. You may have to experiment (again depending on the TV) which setting & connection would give you the best picture;
  • offhand, the component connection (if applicable, the red/green/blue cable) would give the best connection followed by S-Video and last would be yellow (composite).
Please postback results of initial checks.
Good luck and thank you for asking FixYa.
Aug 07, 2009 | KWorld PC to TV (0872880887527) Video...
Toshiba televison picture keeps going yellow
Sounds like the blue is disappearing from your picture. A common cause of this is bad solder connections which can cause the blue signal to be lost at several places. It could also be due to picture tube failure. Sadly, I'm leaning toward tube failure because of your description. Bad solder connections usually take some time to start acting up after you turn on the set, but you say this happens every time within a few seconds. This is typical of a picture tube failure where an internal connection is okay until the tube heats up, and that takes only a short time. A service shop could check the set to make a firm diagnosis, but if the tube is the culprit you should replace the TV. It's not economical to consider tube replacement.
Apr 08, 2009 | Toshiba Televison & Video
I keep getting dis-connected from my internet connection, it says the error is a faulty winsock. i have downloaded errorfix and it says it's all clear, but the same problem still occurs....can you help?
okay Ill be happy to help :-). Ill tell you step by step what to do. Okay go into the start bar. Click control panel. Then select the network and internet icon. Then at the bottom of the window click network connections. The next window you see will have icons that represent all different accessible internet connections. All of the icons will have the image of two computer screens. The icon that has the 2 computer screens that are blue means that your internet connection . You must right click on it and select repair. This should repair you internet connection. If not I am sorry if this doesn't work. And if it doesn't you should try downloading patches for your specific internet provider.
Jul 10, 2008 | Computers & Internet
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
109 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
