Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch logixx 1600 exoress from leaking underneath approx middle
Of machine
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
  • 90 Answers
Check the door seal carefully if no holes,Check underneath for leaking hoses or waterpump.
Posted on May 20, 2009
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
Can't use 1600 spin speed? Only will allow up to 800?
1) read your instruction manual and test the section troubleshooting for indicate what is wrong.
2) if do not have the instr. manual download free from www.fitness.manualsonline.com or www. retrevo.com
3) or you get help ONLINE via chat or phone, call to BOSCH supplier.
God bless you
Jun 28, 2012 | Bosch Logixx WFR 2867 Front Load Washer
Bosch Exxcel 1600 Express Manual
http://www.bosch-home.co.uk/customer-service/download-product-manuals.htmlYou will need to enter the Enr number from the rating plate ( on the inner door trim) use the link, click on Click here to download product instruction manuals. This will open a new window where you can enter your machine model. IU is user info..II is installation info
Nov 27, 2011 | Bosch Washing Machines
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Aug 02, 2010 | Bosch Logixx WFT 2806 Front Load...
F:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Jul 07, 2010 | Bosch Logixx WFT 2806 Front Load...
I can't locate brushes on Bosch Logixx 1600 wasshing machine
hi
usally the brushes are at the back of the motor but depending on motor they could be inside . to get to these you need to remove the 4 screws wich hold motor together. but 1st thing to check is to look at armitor on motor and see if you can see a line going round in the middle. if there is the motor will probley need to be replaced as the motor will have burnt out. but motors are very expensive o these machines. hope this helps
regards dan
Mar 19, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
268 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
