Question about LG LB8000ER Air Conditioner
A/C compressor fan won't turn on by itself.
A/c compressor fan doesn't turn on when ac kicks on. I give it a shove and turns for a few minutes and then stops turning. I had the fan replaced about a 1 1/2 - 2 years ago.
  • joelcord May 20, 2009
    ok, just sat and watched the fan to determine how long it spun for. Turns out the compressor shuts off after about 2 minutes but the fan continues to spin, even after I shut the handler off.
How does changing the bossing of the fan fix the compressor to turn back on?
Posted on May 11, 2010
  • 822 Answers
There is a problem with your fan i'm sure. change the bossing of your fan it will work good.
Posted on May 20, 2009
Could cluster fuse be prob why ac blowing hot? fan blows but hot air
Does the Compressor kick in when you turn on the AC? If it doesn't, the AC compressor is governed by the ECU. My AC went out along with an acceleration problem. hard starting, and unburnt fuel. I had my ECU rebuilt, and upon installation of the rebuilt unit, all worked perfectly again, including the AC.
Nov 08, 2012 | 1993 Lexus Ls 400
2003 mini cooper AC compressor doesn't run
indicates a low gas problem
have it properly diagnosed by an ac specialist shop
Oct 30, 2017 | Mini Cooper Cars & Trucks
Cooling fan won't come on when I turn on the AC
Your bigger problem is the compressor not kicking in. The cooling fan is not coming on because there is not enough high side pressure to turn the fan on. I would start by checking power to the compressor, fuses and relays would be inspect. Check to make sure there is the proper charge of refridegerant in the system.
Jul 29, 2012 | 1988 Chevrolet Cavalier Z24
2005 Jayco 5th wheel-we have been running the ac and it cools great but now and then out of no where the compressor shuts off and the fan stays running. We turn the system off and wait a few minutes and...
When this happens, remove filter at ceiling assy and see if there is frost on evaporator coils/fins. That would cause it to kick out until frost is gone, then kick back in. Get back to me, and I'll give you instructions on what may be causing it.
Aug 30, 2010 | Dometic Rooftop RV Air Conditioner
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
May 30, 2017 | Kenmore Heating & Cooling
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
LG LB8000ER Air Conditioner Logo
763 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
