Retrieving data from a damaged HDD
I have put my damaged HDD from a Toshiba laptop into an external enclosure and, through the USB ports on my other computer, have managed to get some data off it. This was off local disk E. I understand there is recovery software one can buy to try and retrieve data that otherwise appears lost. The problem is I cannot use the cd drive in the damaged computer, so is there something available that can let me do the recovery through the enclosure to my other computer? Thanks in advance.
  • Jerry Haylins May 20, 2009
    Thanks very much - I will try that. Great help.
  • 65 Answers
Download a free demo of Get Data Back for NTFS from http://www.runtime.org/data-recovery-downloads.htm it does the job right. I'm not sure of it's limmitations tho but if you'll need to have it work like it should use this info: Name:Pascal MEUNIER
Serial:DXCMFWHUNPIDTU
Posted on May 20, 2009
My computer will not provide access to the toshiba external hard drive
1)Check that the drive is receiving enough power to spin up. The USB port might not provide enough power, in which case a powered hub or other external power supply might be the solution.
2)Check the cable. A bad connection anywhere in the chain can block current flow, both for power and for data transfer.
3)If you can open the enclosure without damaging it, check that all internal connections are good.
Jun 19, 2014 | Toshiba Computers & Internet
My Toshiba 1Tb External Hard drive Light Isn't coming on!
It sounds like the usb port on the drive itself is shot. You can actually take apart the case and pull just the harddrive out and use a hotswap usb harddrive reader and get to your files again
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Computers & Internet
Good day I am in need of drivers for an LG external HDD hxd7.Reason being my laptop will not recognise the hdd but sometimes it does.
Hi
You do not say which operating system you are using.
You do not say which type of computer this is (laptop or desktop).
Most operating systems do not need extra drivers to recognize a hard drive. The drivers are almost certainly already built into your operating system to operate almost any hard drive.
It could be a faulty USB port (try a different USB Port) or a faulty USB cable (try a different USB cable).
If the cable and port are not the problem, then either the hard drive itself or the hard drive enclosure are faulty (open the enclosure and test the hard drive in a hard drive dock or another (custom) external hard drive enclosure.
I hope this helps.
Aug 29, 2011 | Computers & Internet
Hi! i have an external hard disc Toshiba PX1396E-3T01. i've connected the divice to my pc but the red light doesn't turn blue but instead keeps on blinking blue. what's wrong?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
When I restart my laptop to my HD crashes when windows starts to start, she took the laptop outside and put on another laptop to back up, but when it starts copying, the screen goes blue and restarts...
You will have to take the drive off, put it on an external hdd enclosure with a usb connection, connect it to a working computer, scan it for viruses and spyware, copy all of your data to another device (i.e. hdd, flashdisk, cd, etc). Then, reinstall the hd back on to the original computer and turn it on. If it works it you've solved your problem. If it doesn't then reformat your hdd, reinstall your operating system, programs, and data.
Time consuming? yes but it works.
Aug 17, 2010 | Computers & Internet
External IDE enclosure problem
here's what a sata hdd connection looks like
here's what a IDE hdd connection looks like
here's a page that shows them side by side
Hopefully that should help with what you have there.
Jan 21, 2010 | Toshiba Satellite 2455-S305 Notebook
CPU won't read it im running xp
Ok, here's some step by step instructions.
First is the light on the nexstar coming on when you plug it in, if so what colour? If not try using both USB connectors on the PC end to plug in, it's possible you're not getting enough power if the light is not on as many 2.5" hdd enclosures require 2 USB connections one for power and data and the other for additional power.
Next, if the light is on but no drive in my computer, right-click on my computer, then left-click manage, select disk management from the MCC window that pops up. If your Nexstar HDD shows up here, identify it on the bottom part of the window and report back what is said there.
If it is not there and the light is on, try a different USB port. If the light is not on or you tried the other ports and still no luck the enclosure itself may have failed.
Try moving the HDD into a new enclosure and try again. If this works, Great, if not then the HDD may be damaged and may need a pro to get your files back. If that is the case report back here with your progress and region and I will recommend an appropriate pro.
Hope this helps FixYa,
Chris
May 09, 2009 | Vantec NST-285S2-BK NexStar SX 2.5"...
HDD from dropped laptop
Could it be a power issue? Some older laptop HDs need more power than one USB port can provide and won't spin up properly. If you have a cable with your HD enclosure which had two USB connectors on the end, make sure you plug both into ports on your laptop.
When they don't spin up correctly, you tend to hear them clicking as they try to spin & then cut out. Have a listen to it when you plug it in & see what you can hear.
Sep 01, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Iomagic
Have you looked both in Device Manager and in Disk Management?
Have you tried plugging your external hard drive into another computer?
If it isn't recognized on multiple computers, then you are probably experiencing a hardware failure.
There are a variety of things that can malfunction on your external hard drive:
1) The USB cable - Have you tried switching the USB cable?
2) The external hard drive casing
3)  The hard drive itself
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on our website.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within the warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
I/O Magic Technical Support
Jun 15, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
