Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Paper jam we had a power outage now the printer says it has a paper jam we have cleaned out the printer but still says there is a paper jam.
  • junkersmommi May 21, 2009
    i have tryed every thing and can't find any paper in machine and it stills falts to paper jam.
  • HP Master
  • 13,433 Answers
You most likely have some teared paper still inside.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative solutions if the problem is still not solved.
alternative solutions:
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
How to perform a mechanical hard reset A mechanical hard reset is performed when the printer is in a condition where its normal printing process is interrupted. Examples include a paper jam, printer carriage stall, or mechanical noise. To perform a mechanical hard reset, follow the steps below:
  1. Turn off the printer by pressing and holding the Power button for one second.
  2. Remove the power cord. Wait for 10 seconds and then reconnect the power cord.
  3. Turn on the printer by pressing the Power button. Wait for the Power light to quit blinking and stay lit.
If even after all these steps the problem is still not solved please drop me a comment for further assistance.
Thanks,
Ekse
Posted on May 20, 2009
  • Ekse May 21, 2009
    try putting that thich paper through the machine and see if it helps.
    this will probably not work with your printer but is worth a try, careful, I can't guarantee any positive or negative results with this method since its for another machine.
    http://h10025.www1.hp.com/ewfrf/wc/fastF...
    if noting has helped your printer may require repairs, contact hp for repair service or your dealer. Also check your warranty.
Power outage yesterday, paper jam error message when it came back on. No paper actually jammed, any advice?
Lift the top as if changing the ink cartridges, see if there is anything stck in the belt.
Jul 22, 2014 | Epson WorkForce 600 All-In-One InkJet...
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
Always paper jam on lcd display, even though that the jammed paper was already removed.
If the jammed paper is removed and still show paper jam it means tiny piece of paper is left over in the printer you can use a low pressure vaccum or blower to remove the paper piece before using the blower remove the toner and remove the power plug and the usb connector after cleaning conect the power then the usb then power up printer then in computer click the printer icon in the task bar and remove all the contents then click start settings printer and make your printer default printer right click the default printer and click properties in printer properties click print a test page
Apr 01, 2011 | Canon i-SENSYS MF4120 All-In-One Laser...
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer keeps showing E and saying paper jam but it is not any paper in there
power down. recheck all printer heads are clean, no small bits of paper jammed?
power on
run self clean test if allows the funcionality.
Oct 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have HP printer C4280 All-in-One my paper got jammed
Just press the Power button once. While the printer is Powered ON.
It will try to throw out the Jammed Paper.
Then remove the Power cable from the back of the printer.
Open the Real Door and try to take out the Paper stuck in there. Manually clean the rollers with a lint free cloth.
Jun 02, 2010 | HP PhotoSmart C4345 AllInOne InkJet...
Paper jam but there is no paper
If the paper jam message wont clear, there is something blocking the sensor in the paper path leading the machine to think there is paper. Check the paper path for torn paper. Locate the paper switch/sensor and make sure it is clean and unobstructed.
If the jam message clears but when you go to print it comes back, you may have dirty feed rollers. Clean the rollers with a mild detergent or soapy water and a clean cloth. Do not use alcohol, this will dry out the rollers and shorten their life.
May 18, 2010 | HP PSC 1510 All-In-One InkJet Printer
Trouble following brief power outage
apply any greese material like vaseline on the steel rod on which the cartridge carriage moves.if that rod is become rusty the carriage sometimes cannot move freely on it and this happens,
Nov 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
Paper jam
Turn printer on,
Disconnected power cord on the back...
Press & hold #, 6 keys while connecting power cord, Keep holding till screen shows reset or shuts down..
Make sure the cartridge access door is closed tightly.
Nisar
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
