Question about Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum
Not charging After being on the charger for a long time, 24 hours, it barely starts to run, then increases spead some but not enough to pick up. Can I get a new battery or is it just a goner?
  • 1 more comment
  • need-vac Nov 25, 2007
    We have ours for 2 years now and it does not charge anymore. When we put the vacuum into the charging unit, the blue charger light will go on for 5 seconds then goes off and it does not charge. Does anyone have the same the problem and how can you fix it?
  • Anonymous Mar 28, 2008
    My vacuum will not charge anymore.  I've had it for less than 2 years.  For the cost of this vacuum, I certainly expected it to last longer or at the very least to be able to replace the batteries within a reasonable expense.  I am very disappointed.
  • Anonymous Aug 01, 2008
    Same problem! Owned for 20 months - the nifty blue neon lights go off after 5 seconds. I thought it was the contact points and I adjusted them. Worked for 10 seconds...Electrolux used to be much better than this.
    Any help would be great
  • 328 Answers
There could be reasons for this.
Firstly check the air waves of the hand held unit by inspecting the slide out built in crevice part - if its clogged - remove it.
Secondly, check the brush roll and bellow. The bellow can be inspected by removing one crosshead screw on the back. Be careful with this screw however, because if you lose it the bellow will not be able to stick back on without the screw being in place.
Thirdly, remove the entire brushroll by taking the floor head plate off (I believe a single dime/coin wedged into the plastic screw will undo this) and inspect the toothed spinners at either side of the brush roll - if it has hair entangled up, then clear this.
If you have done all this, the battery is only supposed to be charged for 16 hours the first time and thereafter 7 to 8 hours after each use. The Pronto isn't a particularly strong stick vac anyway and depending on how long you have owned it, it could well be the battery which is now beginning to lose initial power; unfortunately its one of the downsides to ANY cordless stick vac which has a moving brushroll. Hope that helps you!
Posted on Nov 16, 2007
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Room a 620 keeps stopping
It could be clogged with hair (when was the last time you cleaned it out?), it could be the battery isn't holding a charge any longer. It could be getting caught on something . How long is it running before stopping? I found I used to get about a two hour run from my Roomba, before the red light flashed. Then I started to unplug the charger and Roomba when it had a full charge and it wasn't needed. I noticed that after this the Roomba didn't run as long, maybe one hour, before needing a charge again. I leave it plugged in all the time now.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
Neato vacuum display will not come on.
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jul 04, 2014 | Neato XV11 Vacuum
When i take vacuum off charger it doesnt hold charge more than 10 minutes
This condtion is caused by a defective/worn out battery, replace it.
Dec 28, 2011 | Electrolux Vacuums
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
I am charging Remington Shaver FS360 for the first time I have put in charge for almost 12 hrs (the instruction is to charge it for 24 hrs at the first time) but still the charge led is not glwoing. I am...
Wait the full 24 hours then try using the shaver. If it functions normally, then I would say only the charger light is not working. If the shaver runs down before the end of the 2nd shave, then you may have a defective charger and/or shaver. In that case, take it back where you bought it for a replacement.
Jan 06, 2018 | Vacuums
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Very short vacuum cycle time.
the charger sounds like its out take to service center.
Nov 29, 2009 | Roomba Pro Elite Bagless Robotic Vacuum
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum Logo
266 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
