Need parts numbers for both fuse and fuse holder
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
SOURCE: europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
SOURCE: Where can I buy a fuse and fuse holder for my
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
SOURCE: I need a fuse and fuse holder for my Behringer pmp 3000 mixer
It sounds like you need just the fuse carrier...
This is as close as I can find:
http://mouser.com/ProductDetail/Schurter/62002300/?qs=sGAEpiMZZMv1TUPJeFpwblxZ%252bgbqW48rbR6t5kzh87o%3d
The only way to get exact is to go through Behringer or get an exact part number and manufacturer.
Disassembling your unit to get at the part would be a lot of work. I have repaired three of these and am familiar with the unit.
SOURCE: Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
