Question about LG Shine KE970 Cellular Phone
Need help adding new tones for the alarm clock
How do i add tones for the alarm clock?
Save for alarm on iPhone 5c not working
No need to save the alarm. When you select "Alarm" in the Clock app ... you add and Alarm by touching the + sign, enter a time you want to Alarm to go off ... the first time the "slider" that turns the Alarm On/Off will be green - in the on position. When the Alarm goes off you turn if off by sliding the windows from left to right. The alarm will still be saved in your list of alarms ... when you want to add another Alarm, just touch the + sign again. If you want to activate a previously added Alarm, just slide the button to the right to On ...
Feb 24, 2015 | Apple iPhone 5c
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
I have sumsang GT-C3222 phone when i set alarm,it is not working,so plz give me solution as soon as possible
i know you might of already done this but lets do this together
So lets check the tone
Menu> Office> Clock> options> settings> Clock Alarm Tone> make sure its either on Default Tone (you can select an mp3 you have if preferred) To change the tone double tap on Clock Alarm Tone.
May 07, 2011 | Cell Phones
SNK Fratelli Evolution FREV905S-S Stainless Steel electonic clock and timer running slowly
This is from Tim at JMAppliances 2/24/2011:
These clocks are built to operate at 50 cycles(Europe) and 60 cycles(USA) and this is controlled by the audible alarm setting. The clock has to be set on the loudest (highest tone) alarm for the clock to operate at the correct setting. You control the loudness of the alarm by pushing the minus button (second from the right) repeatedly until you here the loudest (highest) sounding tone. Leave it at that setting and the clock will work fine.
Hope this helps
Feb 09, 2010 | SNK Fratelli Evolution FREV905S-S ...
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
Ring tone
Go to system settings and you'll find add ring tones. After adding, go to phone settings and add it in
Nov 17, 2009 | Computers & Internet
Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
Mar 07, 2009 | GE 7-4837 Clock Radio
Alarm clock, LG Shine phone
I just "personalised" the outdoor profile to set the message alert to silent, while still keeping the ring volume on high.
I also picked the divert call option so the phone doesn't ring.
So I just change the phone profile before I go to sleep and divert my calls.
Kind of an awkward solution..I'm considering getting an alarm clock or just using my old phone's alarm clock
Feb 19, 2008 | LG Shine KE970 Cellular Phone
Feeble Alarm sound
you can Update your phone to the latest framework to solve this
Feb 08, 2008 | Sony Ericsson P990i Smartphone
LG Shine KE970 Cellular Phone Logo
374 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
