Question about Kodak EasyShare C142 Digital Camera
My SD high capacity memory card won't work - Kodak EasyShare C142 Digital Camera
    Top Expert:
  • Kodak Master
  • 6,702 Answers
You call it a SD high capacity memory card, but does it say SDHC on the card, or SDXC. our camera only can use Multi Media cards, SD and SCHC cards (max 32 GByte). So no go for SDXC cards. Still a few things could be wrong if you have a SDHC card. The lock switch on the card could be in the wrong position and the card could have a wrong format. If you did format it in a PC, you should have formatted to FAT 32.
But the best format is the format in the camera. Before you do so, be sure there are no import ants files or pictures on the memory card, because they will be lost.
Posted on Jan 01, 2014
5 Suggested Answers
  • 135 Answers
SOURCE: memory capacity
hello sir.,
ur camera can operate normally til 8gb of memory.
make sure u use sd memory
thank u
Posted on Jul 08, 2008
SOURCE: What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Posted on Aug 18, 2008
shockwave727
  • 262 Answers
SOURCE: SD Memory Card
Yes is should work you can used atmost 2GB SD card, but do not use more than 2GB SD card
Posted on Nov 19, 2009
brucecolter
SOURCE: SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Posted on May 04, 2012
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 | Cameras
How do i insert the 8b memory card in the memory card reader? i've tried it several ways and it does not light up??? i need a visual
The Dynex 5-in-1 Reader may be too old to read high capacity secure digital cards. (HCSD)
An 8 GB SD card is definitely going to be high capacity. Only the relatively newer SD readers can read the HCSDs.
Try putting in a 2 GB or lower size SD card and see if it works. If it does, then your card reader doesn't support higher capacity cards.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Why is my new memory did not work with my unit
In the lack of any information about the new memory card, I can only guess that you have obtained a high-capacity card that is too advanced for your camera. There is a difference between SD cards and SDHC (for high capacity) cards. The latter are not backwards compatible with earlier cameras, and some cameras can't recognize a memory card larger than a certain capacity even if it is an SD type.
Oct 20, 2010 | Olympus Camedia C-350 Digital Camera
Micro cd 2 gb memory card is not open pc windo
From Microsoft support:
Some Secure Digital (SD) cards do not work correctly on Windows XP-based computers. Additionally, you may notice a yellow exclamation mark (!) next to the SD card in Device Manager.
This problem may occur even though you have applied other hotfixes that are required for high-capacity SD card support. For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 923293 The 923293 hotfix adds support for SD High Capacity memory cards in Windows XP 934428 Hotfix for Windows XP that adds support for SDHC cards that have a capacity of more than 4 GB
Aug 15, 2010 | Kingston 2GB Secure Digital Memory Card
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
2Gb Micro sd card not recognized by xp pc.
Apr 15, 2010 | Kingston 2GB Secure Digital Memory Card
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
I can not format my memory card
Make sure that the device you are using specifically is to Micro SD High Capacity format and not just Micro SD. If it says just micro SD on the manuals or on the unit, it can only use a 2gb card.
Dec 21, 2008 | SanDisk 4GB microSD High Capacity Memory...
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery Software
You can refer to this card recovery tutorial
Recover files from SD Card
If above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
Dec 09, 2008 | SanDisk 4GB microSD High Capacity Memory...
Kodak EasyShare C142 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
