Vizio horizontal lines
I have thin permanent horizontal lines across the entire left side of my brand new out of the box vizio m551d-a2r tv. cant find anythying on how to fix it or what it could be. i bought it of amazon and reallydont wanttosend it back if i dont have to
  • 395 Answers
SOURCE: thin horizontal line, Panasonic TH-50PX60U
unfortunately the panel is bad. I've worked on a number of these panels to know that symptom. I checked with panasonic and the warranty is one year parts and labor. you may be able to get panasonic to fix it if you still have warranty (purchased within 1 yr.) or check with your state's implied warranty. you might qualify for warranty repair under this implied warranty. call panasonic when you find out about the state's rules.
Posted on Mar 16, 2008
romsky79
  • 822 Answers
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
Posted on May 25, 2009
dsacco86
  • 1077 Answers
SOURCE: We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Posted on Jun 13, 2009
  • 178 Answers
SOURCE: thin horizontal black line appeared lower half of
Fixed non moving lines usually means you have a problem in the panel display or t-con. If it is in warranty get it to a factory authorized service center. If not you can try to change the t-con and see if this fixes the problem, if not then it will be the panel it's self and will be cost prohibitive to repair.
Posted on Sep 01, 2009
  • 14 Answers
SOURCE: Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Posted on Oct 14, 2009
I had a thin horizontal line appear 3/4 of the way across my 60" vizio smart tv. then 3 days later picture went out but have sound. Did the flash light trick but screen is a deep blu color.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 29, 2017 | Vizio Televison & Video
I have a Vizio model M651d-A2r that will not turn on and is unresponsive. As soon as I plug the tv in, the screen displays a horizontal line, a slope line, and a vertical strip of white (see picture).
it is still under warranty ?
One Year Parts & Labor; Free Lifetime Technical Support
ring tech support first
http://vizhdtv.com/contacting-vizio/
first sight of picture says cracked in behind screen
unresponsive is worse
if it doesnt show a picture at any time
looks replace a circuit board or the flat panel
cost of used/ referbished units
http://www.amazon.com/VIZIO-M651d-A2R-65-Inch-1080p-Smart/dp/B00CBQNB7K
May 18, 2016 | Vizio Televison & Video
Vizio how to repair black screen with white lines in the middle
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 22, 2016 | Vizio M551d-A2R 55" 3D LED Smart HDTV
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Samsung 53" LED TV ....4 yrs. old. ....has thin horizontal lines (1 pixel wide) across entire screen
are the lines going left to right or up or down? if up or down probaly a bad panel,iff left or right either the upper or lower buffer board is bad
Nov 28, 2014 | Samsung Televison & Video
Vizio M55------- will not show football scores,time,info
Find the Aspect ratio button on the TV remote. Press it a number of times to cycle through the options. Stop when the picture is the shape you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 15, 2014 | Vizio M551d-A2R 55" 3D LED Smart HDTV
What are the cisco cable box codes for vizio televisions
0281,0227,0294. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 05, 2014 | Vizio Brand Genuine smart TV remote XRT510...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
