New Hard drive
I have just ordered a new hard drive for my Toshiba laptop. It is 250GB 2.5'' SATA 5400 rpm. I bought the new drive from a Toshiba dealer and the actual HDD is a Toshiba make. I have noticed that the damaged HDD in the computer is a Fujitsu make. Will this cause a problem in installing the new drive when it arrives and how difficult is it to actualy install a new drive? Does one just use the installation back up CD? Thanks in advance.
  • Jerry Haylins May 20, 2009
    Thanks for the advice - it sounds as though even a novice like myself can manage this one! Great help - and a speedy reply. A super service Fixya offers!!
    Thnaks a bunch for the info.
    Scholar:
  • 81 Answers
Make sure you de-static yourself before touching either the HD or computer and make sure you take the battery out and unplug your laptop before you do anything. To de-static yourself, plant yourself in one spot, touch a piece of metal and make sure you de-static yourself then begin.
Your new HD shoud work just fine, Its a very easy to install, once you find and uninstall the exiting one, youll see its a peice of cake.
You'll need to reinstall your operating system after your new install.
Posted on May 20, 2009
    Scholar:
  • 93 Answers
The two hard drive names will not make a difference and are compatible. Installing the new drive is not all that hard assuming you have all the programs and the OS. Using the back up OS will be your best bet. Just install the hard drive and then place the back up disc in the CD or DVD drive and boot up the computer. This will act as a temp OS system loading basic features allowing your system to recover from the disc. Just follow the on screen sinstructions and your on your way.
If given the choice make sure you select format the new drive the recover disc may do this for you automatically.
Let me know if I can help.
Joe
TIP: If the old drive is accessable picking up a SATA to USB connector will allow you to use the drive as a slave in your computer to recover some of your saved files stored on your old drive.
    Sniper:
  • 79 Answers
The brand of HDD is irrellevant. as long as its the correct type 2.5" SATA. Install the new drive, and boot to your recovery disk or windows disk, whichever you have. If using manufacturer recovery disk, your all set
Please rate my solution. Thanks
    Master:
    Sergeant:
  • 461 Answers
YOU need to first install the the HD into the laptop, then start installing the OS. Finally the drivers...
Sound simple? If you need drivers.. try below links
http://etech.maiila.com
How can I install toshiba sata drivers when Win7 64 bit is installing?
Look in the bios setting and see if the 500g drive is listed under the advanced tab. Then make sure the 500g drive is first choice for looking for the boot disk. Have your os disk in then save and exit.
Terry
Sep 01, 2014 | Toshiba MQ01ABD050 500GB 5400 rpm 8MB...
Hard disc test failed, boot device not found, couldn'f find 2 HDD'S on system. These are my error codes
Most definitely. If the drive failed a S.M.A.R.T. test or DFT (drive fitness test) then replace the drive and re-install your OS, drivers etc.
Jan 26, 2013 | Toshiba HDD2J95 250GB 5400 rpm 8MB Buffer...
I have removed the MK2546GSX. What can I connect to it to back up the files on this drive?
You should be able to plug a SATA connector cable in to it and plug that in to your desktop PC board and there is power cord adapters. I do it all the time when i am repairing them.
Feb 05, 2011 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
What is the max hdd capacity I can install in a HP ZD8000 laptop?
Your computer uses ATA drives which topped out around 250MB simply because manufactures switched over to SATA drives. It is a pain to change out disks on laptops since you can only have one internal drive. You then have to reload everything.
Here is one I found: Western Digital Scorpio Blue WD2500BEVE 250GB 5400 RPM 2.5" ATA-6 Internal Notebook Hard Drive -Bare Drive
  • 250GB
  • 5400 RPM 8MB Cache
  • ATA-6
I'd consider one of the external USB disks instead to store your data, pictures, etc. You could then put it on your desktop or on a new notebook.
Sep 16, 2010 | HP Pavilion zd8000 Notebook
The toshiba dvdrom drive (Toshiba MK2546GSX) installed in my sony vaio laptop is set to region 2, which I bought in Ireland. I am now in the Philippines and would like to change the region to Region 3,...
You can change the region code on your DVD player only 4 times, then it will lock on that region permanently.
Please click on this link and follow my instruction for solutions to viewing DVDs from different regions :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Sep 03, 2010 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
Well me cd dvd romdose not work well the drive dose but it dose not read my cds
Please check the connection inside maybe it is just loose. If that is SATA connection that is prone to disconnection but if that is IDE cable inside maybe cable loose contack. Try to open the PC and then pull and insert the cable firmly. Restart the computer.
Jan 27, 2010 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
1st Gen Macbook Pro Hard Drive Clicking
store.westerndigital.com or http://www.seagate.com/www/en-us/products/external/
Nov 08, 2009 | Apple MacBook Pro Laptop Computer with...
Gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
Nov 06, 2009 | Gateway M-1625 Notebook
Satellite laptop hard drive crashed
you can have Toshiba MK1237GSX - 120 GB - internal - 2.5 inch - SATA-100 - 5400 rpm - buffer: 8 MB
this hard drive will work with your consisting config.
find it here :
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,MK1237GSX.aspx
Dec 28, 2007 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
