Is there a specific code for paring a bluetooth device with a magellan rodemate 6000t? I want to pair my bluetooth with my GPS, but when I try it says enter in the pass code. I have tried 0000 per the instruction manual, but with no luck. thank you for the help.
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Bluetooth from phone says its paired but the gps won't pair with the phone
