Question about Sears Saws
Craftsman 10860 laser not working
My craftsman accutrac laser turns on but I cannot get it to measure
Hi could be main board problem have you check batteries contacts are clean or key pad fail
Apr 17, 2014 | Craftsman Accutrac Laser Measuring Tool...
I just bought a 12in drill press table top the laser light is not working what can i do ??
make a warranty claim ..most power tools come with a 12 month warranty ..or use it without the laser.. pete
Jan 18, 2014 | Craftsman Drills
My husbands needs an onwers manual for Craftsman 180 degree precision laser level with laser trac mode No. 320.48253 to see what an item in there does?
I think the reason we can't find the manual for 320.48253 is because Ryobi took Craftsman to court claiming patent infringement because of one of the bases included in the Craftsman kit.The suction cup wall hanging base was to similiar to Ryobi's Airgrip base so Craftsman agreed to not sell in the USA no more.
Jan 19, 2013 | Craftsman Laser Level - Sears 180 Degree...
Changing the blase on a craftsman miter saw, model nimber 315.212240
my miter saw has stopped working. i have checked the plug and electrical connection. it worked without problems 2 days ago. it gave no warning of problems. is there "a built in" fuse or circuit breaker?
Oct 07, 2010 | Craftsman 12 In Miter Saw With Laser Trac...
Need owners manual for craftsman laser tech LM013N
Go to the following page you should be able to find it there,
powertool.manualsonline.com/manuals/device/laser_level.html
Apr 18, 2009 | Craftsman Laser Level - Sears 180 Degree...
One green and one yellow light
jasonbonefa remove the cover and check the drive gear. It is most likely stripped.
If the sensor lights are on it means they are working.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 12 in. Compound Miter Saw w/Laser Trac stopped working
If you can provide the model number I can do some research. It could be quite a few things that went wrong. If you are comfortable in troubleshooting the tool let me know when you get it back and I will try and help
Jan 02, 2009 | Craftsman Saws
the hole saw or just the laser part , and ck to see if it has a reset button on the end of motor if so push it in until clicks ,
Jan 02, 2009 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
