Question about Refrigerators
Amana refrigerator model tc20g-w ; mfg #p75535-15ww ; s/n ck32376231-8 frezing no matter where dial is set
Frezes every thing no matter where dial is set
Krazytech
  • 725 Answers
SOURCE: amana refrigerator not cooling
you may have a bad defrost thermostat .. it is on the evapator check it with a ohm meter and see if its open..
let me know
Posted on Jul 08, 2008
dykaar
  • 4 Answers
SOURCE: Sub Zero model 550 bottom
My Subzero 550 did this: The right side of the freezer has a drain that was plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Posted on Oct 21, 2008
woodchuck789
  • 4066 Answers
SOURCE: I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2009
aasc
  • 1606 Answers
SOURCE: Freezer set to 0 actual temp - 1
Set the refrig temp to 42 degrees . Also check to see if the damper (top left in refrig section ) is closing to stop the air flow into the fridge section . Sometimes they will stick due to ice build up inside the damper . Sometimes also , putting a knife inside and wiggling it around , will break it free , however , it may have to be replaced along with the #1 thermistor .
Posted on Aug 09, 2009
engg_cool_bo
  • 236 Answers
SOURCE: THE FRIDGE IS FREZING UP AT THE BACK THE DIAL IS
PLEASE fix your dial at 6-7, then you will be able to solution.
Posted on Oct 06, 2009
Frezes everthing,too cold
then turn the dial for tempature to a smaller number
Mar 07, 2015 | Amana Refrigerators
DOES NOT SHUT OFF RUNS AND FREZEES EVERY THING THANKS JIM
    May mean that the closing band of the door does not seal properly, but rather in most cases the thermostat is faulty
TRUE THERMOSTAT 800393
Aug 13, 2013 | True GDM-10 Refrigerator
My haier mini fridge is frezing everything and i have it on its lowest thermostat setting what is wrong with it
just a suggestion: but you might have to much coolent in it, or its useing alot of power,maybe too much power and the fan is spinning at a high rate,IDK maybe thats it.it probably wont help you though
PS:maybe take it to a shop
Jun 08, 2012 | Haier Refrigerators
My fridge keeps frezing up
There's a little dial or knob to set the temperature of your fridge, just wind it down to about 4 if it has a number setting and that should keep from the contents freezing up.
May 06, 2011 | Hotpoint HSS25GFP Side by Side...
Ge model # tff34rvf refrigerator runs then shuts off for a long time. frezer makes ice and frezes items then things thaw agan
run times are to long . caused by dirty cond coil or fans running too slow . clean coil first this may correct problem . if not , the the cold control may be failing so replace it next .. and clean it reg . as it will nt cool when dirty .. mm
Jan 07, 2010 | Refrigerators
It frezees vegitable in vegitable compartment & in frezer ice / ice cream turns into liguid
a refrigerator when not defrosting will get too much ice in the freezer and work the compressor too hard resulting in a freezer that is too warm and if you dial up the thermostat to compensate will result in freezing your vegetables and fruits in the crisper      make sure the back wall of the freezer is not iced up   if it is then either the heater cable is broken, or a thermal cut off failed  or the defrost timer has failed
Nov 08, 2009 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
THE FRIDGE IS FREZING UP AT THE BACK THE DIAL IS SET TO NUMBER 1
Oct 06, 2009 | Hotpoint RLA30 Compact Refrigerator
Freezer wont freze
Clean cooling coils. Check refrigerant level.
Jul 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frezeeing when og on line
You might check out the Informative article at Ezinearticles.com to fix the freezing problem as the article ives the information about a DIY guide, (though i don't remember the name of the site) but you can check the article from http://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369
Jan 05, 2009 | Microsoft Xbox 360 Console
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
