Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
My hitachi 57f500 turns itself off after 3 hours of use. Turning it back on restores the picture,
My hitachi 57f500 turns itself off. Turning it back on restores the picture. This happens after the tv has been on for approximately 3 hours.
  • 431 Answers
Hi I am Vortash
There may be actually nothing wrong with your set ? .......
This set has an anti surge protection circuit and it is designed to shut down should the incoming power peak above 240 volts or more , is this happenig at random times or around the same time in the evening or day it may be that this safety device is protecting the set .. sometimes local area transformers peak at the time of most consumer requirements this may just coincide to when you sit down to watch tv .. however if it has a habit of doing it at different times during the day .. then this safety circuit may be at fault and require an engineer to service the tv and check for poor components that have changed value .. It explains this is in the manual if you do not have one for your set you can download one for free from http://www.safemanuals.com hope this is of help regards Vortash
Posted on May 20, 2009
The picture has a red color
You need to First turn Color Off In the Menu then, Find the Screen and Focus Control Block
adjust the Red/Green/Blue Screen drives To a Black and White Picture, Then Go Back to Menu -Color and turn Color Back on.
Remove the Front Bottom Panel and Control Block is behind it. It will have 3 controls on top for Focus and 3 under them for Screen Drive to each Tube R/G/B
Jan 25, 2011 | Hitachi 57F500 57" Rear Projection...
Tv keeps turning on an off on its own
This is a shot in the dark... but maybe your remote on/off button is stuck. remote broke/batteries low. Any new wireless devices in the room? If none of the above I would guess that the power button or the remote signal reciever on the TV itself is shorting out. I hope this helps.
Nov 29, 2010 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500 blurry picture
its the convergence problem in your tv.the ic needs replacement.to fix the problem.its worth getting it fixed.get it repaired.
the cost will be negligible.
Mar 21, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Hitachi 57F500
That means you don't have high voltage and that could be anything from a bad connection on the main board to a fist full of parts. It is not a do it yourself job when it comes to component Laval parts replacement .. You will need a service man
Apr 16, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500, Dark areas
Hitachi dark problems at ctechnicians.com
Dec 27, 2007 | Hitachi 57F500 57" Rear Projection...
No picture on my hitachi 57f500 when i connect hdmi to dvi from new dvd Player
If you have a 2006 or later model, you must set up Blue Ray DVD to Auto Mode on their output setting.
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 57f500
You may have a bad convergance chip, a bad CRT( picture tube ), CRT Board ( board pluged into the picture tube),or a bad video chip. Although this is somwhat a common problem on this model of set, I have found many different fixes. Sorry I can't be of more help. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 12, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
139 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
