Question about Plumbing
Where can I find a replacement shur-dri model sd-520c impeller housing.
3 Suggested Answers
  • 832 Answers
SOURCE: Where can I find a replacement impeller for a
Connect to the internet and type;
http//www.merchantcircle.com/business/Shur.Dri 419-289 1144.
This is where you can find your ShurDri Pump parts.
Posted on Oct 26, 2009
SOURCE: I have a Shur-dri SD-106 pump. I am looking for a
call 888-987-8677 this a division of pentair they make shur-dri pumps
Posted on Jan 10, 2011
I have a Shur-Dri 1 HP above ground pump, Model No. SD-100-01. The propeller is cracked and needs to be replaced. I cannot find anyone who sells just the propeller. They say I have to get a new pump. ...
There is a possibility that this model is not supported any longer. What you are needing is an IMPELLOR. The company that makes sure dry has a lot of information here: http://www.pumpproducts.com/myers-m-39.html
Jan 23, 2015 | Pool & Spa
My shur-dri model sd-100-01 well pump will run for a while and then shut off but will restart after an hour or so. What's wrong?
It is a heat sink in the motor. Most all electric motors come with it. Once it cools down, they work again. The heat sink keeps them from burning up.
Oct 26, 2014 | Cars & Trucks
My Shur-dri model SD-100-01 runs for a while then shuts off but restart after an hour or so. What's wrong?
It's could be the high temperature switch cutting it off and after it cools down it resets itself. Check the vent for any lint build up. Clean it out and make sure the vent hose doesn't have any sharp bends in it.
Oct 26, 2014 | Dryers
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
Need to prime Shur Dri SD-520C T7
OK, prime away. May be you should reboot the computer first.
Dec 15, 2012 | Computers & Internet
Shur-dri sdts10-01 water leaking from shaft around impeller housing
Mine is too. But I have not had any useful replies to my simple question about "where is the level sensor".
SoI agree FIXYA looks a complete scam!!!
Dec 13, 2012 | Dishwashers
The impeller has quite a bit of movement in the housing which is causing it to rattle around and make a lot of noise. Would replacing the impeller solve this or is the housing damaged?
The impeller is supported at both ends with rubber bushings the impeller shaft wears into the rubber and enlongates the hole this happens over time or if you run the pump dry often. The rubber parts are replaceable.
Apr 14, 2011 | DANNER Magnetic Drive Utility Pump 110 GPH
I have a Shur-dri SD-106 pump. I am looking for a source to purchase replacement impellers. Please advise
Sep 15, 2010 | Plumbing
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Where can I find a replacement impeller for a Shur-Dri SD-106 pump?
Oct 25, 2009 | Plumbing
Plumbing Logo
194 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
