Question about Apple iPod nano
Do not disconnect sign on IPod when plugged into laptop
Hi when I plug IPod into computer to charge 'Do not disconnect' and red sign starts flashing on the IPod screen? It wont respond to anything I press. Please help I dont want to disconnect incase I lose everything. Thank you.
  • dornemorton May 20, 2009
    Thank you so much for responding so quickly and solving the problem.
  • 65 Answers
If Itunes is not on, you can disconnect it, don't worry.
Posted on May 20, 2009
Ipod is acting funny and its not working
Yes. Wait for it to charge. You've probably run the battery COMPLETELY flat. Your ipod will turn off with a little charge left, to keep the flash memory ticking over so you don't lose all your data. If you left it too long, even that will run out. Just leave it to charge, completely. If that means 3 hours, then wait that long, because it'll be a lot better for your battery life in the long term.
Sep 30, 2009 | Apple iPod touch
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
Jul 10, 2009 | Dell Inspiron 6000 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Ipod nano 2nd gen will not charge or do anything. Does not have the do not disconnect sign on it when plugged into the computer.
if you have itunes on the computer then there should be no problem unless your computers driver is shot. so i would get a wall charger, from a local **** smith or somewhere, and see if it will charge off the wall. if so then there should be no problem, and if then it does not charge it is proof that your ipod is shot, so perhaps its time to get a new one. please rate
May 12, 2009 | Apple iPod nano
The i pod is not showing that it is charging
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Dec 30, 2008 | Apple iPod nano
Ipod 30gb black
hold the menu and center button for 25 seconds.
That will reboot it without damaging your data.
Jun 26, 2008 | Apple iPod MA446LL/A MP3 Player
How to unlock ipod nano2gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Im here to help.
Apr 04, 2008 | Apple iPod nano
80gb black ipod video
If you need more assistance let me know. I'm here to help.
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod nano, white and silver, flashing the apple sign
I had the same problem and I just let it alone, plugged into the computer (even though it had plenty of battery) for about 10-20 minutes and it came back! I hope this helps you :)
Aug 07, 2007 | Apple iPod nano
Apple iPod nano Logo
112 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
