Cbh508 drivers won't install on my laptop
I can't download drivers for this device: CBH508 Bluetooth stereo headset.
  • 77 Answers
SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
Posted on Jan 13, 2008
SOURCE: IBM T43 Bluetooth not working
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Posted on Jun 16, 2009
SOURCE: Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Posted on Jan 28, 2010
  • 12 Answers
SOURCE: Samsung sgh-t139, Bluetooth won't recognize my laptop
Open bluetooth software, open add device, make sure phone is set to visible, then search devices, pairing code should be 0000
Posted on Jun 02, 2010
SOURCE: XTM-1200 Drivers not found in
the answer is easy....buy a bluetooth device.....it will install a new software that is not in ur laptop...and it will work perfectly
Posted on Jun 27, 2011
Where can I find drivers for bluetoth cbh508
You don't find drivers as it's Bluetooth
You enable Bluetooth on your laptop and then pair the device.
Sep 15, 2015 | Computers & Internet
CAN'T FIND WIN7 DRIVER FOR BLUETOOTH HBS-200 HEADSET
Unfortunately, Windows 7 removed native support for bluetooth headsets, for absolutely no reason.
The drivers are actually not needed for the Headset specifically, but rather for the A2DP and AVRCP profiles and audio sink. The downside is that Microsoft's Bluetooth stack does not support either of these.
So you need a Better Bluetooth Stack, so it understands all of the virtual Bluetooth devices.
These directions work for almost any headset that has issues when connected to Windows. Sadly, there is no really good well-defined set of drivers for Windows Bluetooth, so it will frequently take some finagling.
1: Find the correct and absolutely most-up-to-date drivers for your Bluetooth hardware on your computer. In -MOST- cases, the chipset is Broadcom, however manufacturers such as Dell and others tend to put some odd wrappers around the chip so their drivers are required. If not, the direct-from-Broadcom drivers will work.
2: IF the Bluetooth hardware is already detected by Windows, delete it from device manager. Reboot the computer if this was done.
3: On reboot, Windows may detect it and reinstall it fresh. This is fine if it does. Allow it to install and reboot if it requests.
Once the Windows stack is installed properly, you can install the updated stack. With Dell drivers and other OEM computer manufacturer drivers, Windows may not detect it to begin with, however having Windows drivers first is not necessary with these drivers.
4: Install the proper driver. With the Broadcom driver, this will only work if Windows has already installed. With OEM drivers, this is often not necessary. Reboot if necessary.
With the happy stack installed, and the headset paired, you will find that instead of just Handsfree Telephony and Headset services, you will also have Remote Control and Audio Sink services.
Headset/Handsfree: Mono 38kbps audio out and also a microphone input. This is what is used for phone calls. It sounds horrid, mind you.
Audio Sink: Stereo happiness and joy. No microphone input.
Once you have these devices, you do need to set your audio playback device appropriately for Stereo Happiness and Joy.
Mar 27, 2014 | Radio Communications
It will not connect to my windows 7 laptop
Can you add it via "Hardware and Sound?"
Click start, go to Control panel, Click hardware and sound. Under "Devices and Printers" there is the option to "add a device," Try adding it there.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 08, 2014 | Craig Computers & Internet
Armel mini BA023 bluetooth can it be charged by mains apdator
This means that the driver software was not installed correctly when you connect it at the bottom of the screen it may say the driver software wasn't installed correctly in the event of this click on it and reinstall it but unplug any other usb devices other than the device affected
Dec 08, 2013 | Armel Creddeal-wireless Bluetooth...
I tried connecting my nokia bh 503 head set to my HP probook and when it finishes connecting it says device driver not successful
You need to have the bluetooth driver for BH-503. Please find the link on the download site in the link provided below.
http://kamistad.net/free/free-nokia-bluetooth-stereo-headset-bh-503-download
Thanks.
Jul 02, 2011 | Nokia BH-503 Bluetooth Headset
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
May 06, 2011 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
My hbh ds-220 bluetooth headset can't work with windows 7 x64, i search the driver and didn't find
Win7 will automatically download & install the required drivers for your SE HBH-DS220 BT headset. After installation, right click the speaker icon in the taskbar and select Playback Devices.
Set the HBH-DS220 stereo as your Default Device...
Mar 03, 2011 | Sony Ericsson HBH-DS220 Wireless Headset
Can i have how to connect Nokia BH-214 bluetooth headset pair in acer laptop(Asper5742)
from OFF state of your BH-214, press power button until LED flashes quickly,do not unhold, stay holding & press power button until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. I used Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer), work fine with my BH-214 to connect with PC (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile). Applied CSR bluetooth dongle 2.0, got from store for only $2.50.
Jan 04, 2011 | Nokia BH-214 Bluetooth Stereo Headset
I want to use this head set as playback head phone with my laptop (having bluetooth) while using windows 7 proffesional x 86 edition is it possible? if possible then how can i use this one please reply...
Tool; CSR bluetooth dongle 2.0, got from store for only $2.50.
Install Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer). from OFF state of your BH-214, press power button until LED flashes quickly,do not release the button, stay press until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. Work fine with my BH-214 to connect with PC through BTooth dongle (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile).
Dec 20, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Drivers not installed on win 7 BH-214
Install Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer). from OFF state of your BH-214, press power button until LED flashes quickly,do not release the button yet, stay press until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. Work fine with my BH-214 to connect with PC through BTooth dongle (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile).
Dec 02, 2010 | Nokia BH-214 Bluetooth Stereo Headset
 Grubhead
Grubhead
