Question about Procom Heating & Cooling
My procom md300 tba heater fires but after about 10 seconds both the flame and the pilot shut off
The pilot works and will continue running, but when I turn the knob to fire the burners it works but shuts off both the pilot and the flame after about 10 seconds
bluegreenash
  • 661 Answers
SOURCE: reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Posted on Nov 02, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: model SRPH02 BURNER WILL NOT FIRE
Bad flame sensor. Try to clean it with some steel wool
Posted on Apr 24, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heat n glow fireplace comes on fine with all
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Posted on Nov 05, 2009
  • 288 Answers
SOURCE: Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Posted on Jan 07, 2010
SOURCE: My vokera linea ag plus domestic hot water cycles
I have the same problems, did you manage to get it fixed and what was wrong?
Posted on Mar 08, 2010
Procom heater will not stayon
check the milivolt reading with a tester or replace the powerpile/pilot assembly
Sep 30, 2016 | Procom Heating & Cooling
New blue flame heater, everything is hooked up, gas is going to unit, I have a natural gas hookup, in the correct port, knob is turned and locked into the NG position but unit wont light. There is gas...
do you have the pilot light burning if not then you have to get in burning first
Put knob in pilot position push down and hold for at least 30 seconds or longer then if there is an igniter push and release it push and release till pilot light comes on .Continue to hold pilot light button down for another 10 seconds or so, release pilot button and turn button to on or up a number or set T stat
Main flame should come on and burn
Oct 13, 2013 | Procom Heating & Cooling
I have two 7 month old Pro Com vent free gas garage heater ( Model Number MD300 TGA Propanr heaters. I use them for emergency heat during power outages in my greenhouses. Last year they worked perfectly...
Are all three now connected to the same source? That might have something to do with it. Anyway a safe and easy solution is to flush the pilot assembly with Rustbuster and allow it to dry . This clears the pilot of dust and cobwebs without disturbing the innards of the vent free safety pilot. Muck that uo and you will have to buy another. Get yourself some rust buster.
12_1_2011_9_38_55_pm.jpg It has a flexible tubing that fits right into the pilot.
Nov 30, 2011 | Procom MN300HGB Heater
LLG325N Larrs heater wont stay running. Replaced the pilot assembly. It fired up for about 10 seconds and then quit.
You should have a flame sensor wire going to your pilot. Make sure that it is hooked up correctly. If the sensor isn't relaying flame to the control box it will think you don't have a flame and will shut off gas flow for safty reasons. So be sure the wire is connected and in good shape. I hope this helps.
Aug 14, 2011 | Jandy Laars Hi E2r Heater 350k Btu Natural...
Vent Free Blue Flame heater: shuts off
Sounds like a gas pressure problem. Have your gas company check the pressure.
Jan 31, 2010 | Procom (177653) Utility Heater
Pilot goes out with fire place
is there a power phile on the fire place
Jan 16, 2009 | Procom ML300EBC Heater
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Heater runs 2 min. shuts off
Aim the pilot flame harder down the thermocople.
Willis
Feb 11, 2008 | Procom ML300EBC Heater
Heating & Cooling Logo
Top Procom Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
