Question about Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to... InkJet
Replaced cartridges printer now will only print in pale pink after putting in new cartridges. Tried cleaning then putting in black only but it will not print clearly - then did same omitting black and putting in colour - comes out pale pink only. When both cartridges are in place - black misses tops of some lines - will print quite a bit of a page OK then has this hiccough. Doesn't do it if I change type to say, red, blue, green etc - colours print perfectly. Sorry two separate Pixma ip2000 printer problems, mine and daughters. All help is gratefully received (I have added daughters problem with mine she is 'out bush' and cannot get internet connections. I have somewhat the same problem, and I just replaced the cartridges, but I really don't like wasting paper and ink.
  • 65 Answers
Keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
Posted on May 20, 2009
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
Epson wf-2530 - cyan is printing out as a pale pink even after inserting a new cartridhe
My suggestion is to pull the cartridges check your ink collector pad. This is where the extra ink gets wiped from the cartridges as it goes by. make sure that the pad is not pooling up check the bottoms of your cartridges and wipe them clean also and do a quick cleaning inside if you see any extra dust, ink etc.. just wipe it clean. then power your printer off and back on again and see if that helps. Hope it does the trick for you.
Nov 08, 2014 | Epson Office Equipment & Supplies
I put new print cartridges in my 960c printer. They are hp 78 for color and 45 for black and white. my orange ink light will not stop blinking. It is not printing
I have an HP DeskJet 1220C that has been working fine for two years now. All of a sudden it can only print in pink and black. It is driving me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
Aug 25, 2011 | HP DeskJet 960c InkJet Printer
Clicking noise when printing
Had similar problem. Putting my hands on the front surface of the printer, the click seemed to be felt strongest in front of the pink ink cartridge. I took the cartridge out, looked at the back of it, where there's a little black wheel, and tried turning it. That wheel was stuck (whereas the other colors & the black would turn). Tried printing with the pink cartridge out and no more clicking noise. I guess I'll just replace my pink cartridge. Maybe see if there's a similar problem with one of your cartridges?
May 13, 2010 | Samsung CLP 300 Laser Printer
Printer wont print the right colour
You might have selected the wrong profile for your preferences. Go to printer properties and select defaults for all. This will solve your problem. If still facing problem comment back.
Sep 07, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Replaced cartridges
Hi there :
on mine i had to use some rubbing alcohol and clean the new cartridge and the contact area on the p[rinter then reinstalled the cartridges and kept running the cleaner program and then about 15 sheets of paper later it finally cleared up and the color returned to normal and i had no more prohblems
Mar 07, 2009 | Canon PIXMA iP2000 InkJet Printer
Kodak aio 5100 all in one just prints red/pink
An inter active website is being provided by Kodak to help their customer w/ this issue.....Try using www.kodak.com/go/itg and use missing colors for sub class if this does'nt solve the issue call Tech. support. (1 800 421 6699)
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to... InkJet Logo
221 people viewed this question
old marine
old marine
