Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Spitting and sputtering
I have a husqvarna YTH2448. It starts fine, but spits and sputters badly. I changed the fuel filter, cleaned air filter, cleaned fuel cap breather hole, checked spark plug connections. What else can I do? When it spits and sputters, I can control it to a degree by pulling out the choke a little. It only happens when the mower is not engaged. When I engage blades, it runs fine. What am I missing? please help.
Mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
My 2003 Astro van has been running fine the I got gasmonday night and as I pulled out the gas station it spit and sputtered like I got bad gas or trash in filter, then it started working fine.
Mass air flow sensor maybe drity or going bad . Ever had it replaced ? Have you replaced the air filter lately ? Video's on youtube showing how to clean mass air flow sensor , you would have to buy a can of mass air flow sensor cleaner . Also while your at it clean the throttle plate , again there are videos on youtube . How did you check fuel pump ? To do it right you would need to hook up a pressure gauge . Also check flow .Videos on youtube .Has the check engine light come on ? Also you mite try some fuel injector cleaner and or dry gas for moisture in the fuel !
Mar 15, 2017 | Cars & Trucks
Why does it continue to spit and sputter going uphill?
Spit and sputter can happen because of not enough fuel or air. last thing to check for fuel is the fuel pressure regulator. On the air side would be the the air filter(filthy) or catalytic converters(clogged). on the mechanical side, Could be bad rings, burnt valves. Compression test would find this.
Mar 07, 2016 | 2002 Chevrolet Silverado 1500
Honda Shadow, spits and sputters
Put a spike air filter on my 06 honda shadow spirit 750cc and now it spits and sputters won't go past 35 with out spitting and sputtering
Jul 01, 2013 | Motorcycles
Spitting and sputtering like not getting fuel
It may have fouled your plugs, but you can tke them out and clean them. Use a small blade and scrape the carbon off.
You could also take the egr valve off and try to clean it. Use a wire brush. also clean as best you can the passages under the valve, they can get plugged with carbon. Use a new gasket when you bolt the egr valve back down. Keep trying to get the fuel filter off, but the egr cleaning should help.
Nov 27, 2012 | 1997 Honda Accord
My jimmy will start and idle just fine however when I start to drive it,it sputters and spits then stalls out. when I restart it I have to floor it to get it to start again. if I rev it to about 6-8000...
i would suggest changing the fuel filter if this does't work check the fuel pressure. and get a mechanic to check the ecu fault codes. as this could be caused by a electronic fault.
Mar 09, 2011 | 1996 GMC Jimmy
Heater sputters and spits
change nozzle, check fuel tank is clean and fuel line and filter are clean
Oct 29, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
1995 Jeep grand cherokee is missing while running. When it is under a heavy load (driving fast) it runs fine. When idleing and slow driving it spits and sputters.
I have the same problem on my 95 grand cherokee laredo. Sometimes it starts out fine and after about 10 miles it starts spitting and sputtering. Then after a while it seems to clean out and run fine again for a little while. Then other times it starts out spitting and sputtering at the begining. I changed the fuel filter and that was not it. It is a 4.0L 6cyc. Any Ideas?
Thanks,
Broken Arrow, OK
Jul 02, 2009 | 1995 Jeep Grand Cherokee
Van Sputters And Loses All Power When I Accelerate
Internal combustion engines requires 3 things... fuel, air, and spark. You do not have enough of one or more of these. If the wires and plugs are old, change them.  Air filter, same thing.  Fuel filter can also clog up with stuff after awhile. When you take a look at the air filter check where the air comes from.  It is possible a little critter has built a home and blocked the air flow (rare, but, it has happened).
May 07, 2009 | 1993 Plymouth Voyager
Car spits and sputters
Major vacuum leak? Do vacuum test. Clean
injectors and check fuel filter. Check timing
too.
Aug 23, 2008 | 2002 Pontiac Firebird
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,176 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
