Question about Breville Bdc600xl YouBrew Drip Coffee Maker
Water level inaccurate
First fill read 12cups, now reads 10 cups, although the tank is full and the red float indicates max fill (actually leaking water out of the rear overflow) This is the second machine to show this problem-- bought it last week, exchanged yesterday, this one does the same. Can using distilled water confuse the water level indicator?
4 Suggested Answers
SOURCE: Just finished setting up...everyworks but no water comes out.???
We got the Breville ESP6SXL as a gift from Crate and Barrel. I Put water in the tank put the tank in the machine and nothing but a loud vibration came out. I tried everything to get it to work and on one attempt noticed that a few small air bubbles come out when I dropped the tank in place. this means the air in the machine is creating a barrier that prevents the water from going into the machine. (priming process) I lifted the tank and pressed it down in and out for a while 20-30-50-100 times eventually drop by drop enough water gets into the machine to create a vaccum and this is what sucks the water from the tank into the machine. I suggest trying 20-30 times, make sure its heated up and turn it to brew, if it doesn't start working with 30 seconds, try another 20-30 times. I was going for a while and air bubbles kept coming out every time I dropped it back down. air bubbles were still coming out when it finally did start working so you don't have to get all the air out it just needs some water inside to create the proper vaccum. This will work, I tried calling Breville and was on hold forever... Good Luck Hope this helps Ken
Posted on Jul 14, 2009
  • 8 Answers
SOURCE: I only get half of
Did you allow the vinegar to remain in your BKC700XL, undisturbed for, 4 hours with the power on, before running fresh water through your unit.....IF NOT TRY THIS, FIRST.....sometimes it takes more then one flush, to clean a BKC700XL,,,,, Please post your results, if this works for you, And even if it does not.
Posted on Feb 26, 2011
SOURCE: Hi, I just bought Brevile 820XL
If you read your manual, it explains how to program the machine to allow the amount of water that you want to have per cup.
Posted on Oct 14, 2012
Gaggia syncrony compact digital expresso maker says fill water tank but water tank is full
Check the float in the tank that indicates the water level to the sensor. They often fail to float, solution is to either replace the tank or jam something plastic under the float to lift it to the top of its slot.
Jan 01, 2016 | Gaggia Syncrony Compact Digital Espresso...
When gas tank gets to about 1/4 the car stalls when making hard or long right turns
Gas level sensors are very inaccurate, they become especially so over time. If you judge your gas level by your gauge reading - most probably by the time it shows 1/4 tank it is actually almost empty. When you make a right turn (or brake hard) the remaining gas in the tank rushes away from the gas pump intake. It usually means that you have about a gallon or less fuel left.
Solution: Set up your trip odometer every time you get your tank full, then read how many miles you traveled since your last fill up - you'd know how much gas you have left. Or replace your gas level sensor for a good new one. If you have to drop your gas tank to do that it is usually not worth the money.
Jun 09, 2012 | 1997 Oldsmobile LSS
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Jaguar fuel gauge problems
sounds like you got the float stuck when you installed the new part, have seen this hapeen often
Sep 14, 2009 | 1992 Jaguar XJ6
Low Coolant light
Sounds like your sensor unit in your coolant overflow tank. Like nearly everything man made that floats, they will eventually leak (become water logged). This is a relatively cheap fix, as long as the light is coming on and the coolant level in the overflow tank is between the MIN and MAX lines in the overflow tank. This means that the float in there is dropping below the actual fluid level (watter logged) and you need to get a replacement sensor unit (aka sending unit) for the overflow tank.
Otherwise, if the coolant level in the overflow tank IS BELOW the MIN level line on the tank, then you are losing coolant somewhere and that is when things start to get expensive (might be a radiator problem, head gasket, cylinder head, heater core, etc).
Jul 19, 2009 | 1997 Pontiac Grand Prix
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Water container full but low indication on
I think the water level is read by a magnetic pick up driven by a black floater located 3/4 way towards the back of the water tank.
Make sure this floater can move up and down in its pocket: you can see it through the walls so just shake the tank to see it move, and check that it floats up when you fill water
Mar 30, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Gas gauge reads full all the time
hello, it sounds like it has something to do with your fuel sending unit located inside your gas tank,on the sending unit it has a float arm that reads the fuel level, some times that float arm gets jammed and wont show your actual fuel level,to fix this with your gas tank at least half full use a rubber mallet or any other object that wont damage the tank and with your key in the start position with the car not running but reading your gages hit the gas tank not to hard but hard enough to lodge the float arm loose, if this is unsuccessful then it will probably be a bad fuel sender location sensor located on the actual fuel sender if that's the case you'll need a new fuel sender. good luck and please send me a update or any questions let me know.
Mar 24, 2009 | 1997 Pontiac Bonneville
Gas Gauge not reading correctly
The most likely culprit is the sending unit in the tank. They are relatively easy to change, as long as you don't have much fuel in the tank. It's a mechanical unit that has a float that raises and lowers with the fuel level, however with age, the floats can develop leaks and no longer float, of the electronic portion of the unit can go bad and not register the proper level. They are replaced and an entire unit, so it doesn't matter which happened, you will need to change the fuel tank sending unit.
Jan 11, 2009 | 2004 Ford Explorer
Breville Bdc600xl YouBrew Drip Coffee Maker Logo
77 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
