Question about Bissell 89Q9 Bagless Cyclonic Vacuum
Bad micro switch bissel lift off revolution - Bissell 89Q9 Bagless Cyclonic Vacuum
reddevil6
  • 1673 Answers
SOURCE: Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Posted on Jan 21, 2008
advacak
  • 125 Answers
SOURCE: BISSELL - Lift-Off Revolution Pet
check your belt
Posted on Dec 22, 2008
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
  • 5 Answers
SOURCE: How do you change the belt on the Bissell Lift Off
http://www.bissell.com/images/UserGuides/3750_905.indd.pdf
Posted on Aug 17, 2009
  • 4088 Answers
SOURCE: My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
Posted on Apr 13, 2010
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a...
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Jul 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
My bissell lift off will not pick up, there are no blockages and suction is still strong
You can fix it easily. All you need to do is change the belt and you'll be good. Here is a link to the belt you need and the manual which has instructions.
Bissell Lift-Off Revolution Belts and Manual
Bisslll Lift-Off Revolution User Guide
Nov 15, 2009 | Bissell 3750 Lift Off Bagless Upright...
I cant find my manual to clean my Bissell lift of revolution
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jan 03, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell liftoff brush wont turn
Check the connections on the bottom of the lift off part, and the matching connector on the bottom section. If bad, take it to a warranty repair shop for Bissell. Other wise it could be the brush motor that is bad, or the switch is bad.
May 15, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Jan 20, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 89Q9 Bagless Cyclonic Vacuum Logo
27 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
