My AC fan is only working intermittently. (2001 Chrystler Voyager) It will turn off and turn back on later for a few minutes, then off again. Is this something I can fix myself?
Check the fan blower resistor mounted in the under dash blower case. Mazda had pretty well designed systems and are user friendly. The resistors are a fairly common issue. Make sure also that the drain on your ac unit is draining out when the ac is on. They can fill up and cause some weird probs. check also that the carpet under the pass side dash is not wet. If so, you have a drain that is clogged or is leaking back int the dash floor. There is a repair for that also.
