Question about Carrier HUMCCSBP2412 HUMCASBP2412 Humidifier Filter Evaporator Furnace Pad 2-Pack
Carrier weathermaker 9200 humidifier evaporator filter
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a Carrier Weathermaker 9200 furnace
Here is the replacement for that unit...the price is not bad either...
http://www.appliancefactoryparts.com/humidifiers/carrier/49fh024120.html
heatman101
Posted on Nov 30, 2010
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
How do I fix my blower problem on my humidifier?
Free Sears Humidifier User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > ... > Household Appliance Sears
Products 1 - 11 of 11 - Sears Humidifier 758.144120. Sears Kenmore Evaporative Console Humidifier Owner's Manual. Pages: 0 Saves: 0. See Prices
Oct 29, 2015 | Kenmore Quiet Comfort 12 Humidifier Filter...
I have a carrier weathermaker 9200 - Water is leaking from under the furnace. I have checked the humidifier and in the furnace itself and cant find where the water is coming from. The furnace runs and...
Chances are it's from the condesate tubes or collector box. If not, you may have a cracked A/C drain pan- lots of installers over tighten the male adapter into them and cause cracks. next check to see if they installed all the condensate plugs at install, some installers don't- read the manual in the "how to set up the condesate" section and trace EVERY tube to make sure they are routed correctly and not cracked/ cut/ nicked. Most furnaces are multi-position now and some installers don't move every tube nessessary... Hope this helps, if not, post a close-up pic, and I'll pinpoint the bad spot for you...
Feb 22, 2013 | Carrier Humidifiers
My humidifier is a Carrier and uses the square evaporator cartrages. There is a drain pipe coming out of the bottom that goes to a floor drain. I've noticed that there is a slow drip here all of the...
Hello, no the humidifier should be running only when the blower motor is running. Sounds like the solenoid valve is faulty if water keeps drainig from humidifier.
Sep 25, 2011 | Aprilaire 700 Humidifier
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
Jan 28, 2011 | Honeywell HE220A1019 Whole House...
Carrier SBP Humidifier is not working
I would suggest turning up the humidistat (usually located on the the return air duct to a higher setting and listening for a "click" noise on the supply valve. If you do hear a click but dont see / hear any water than the culprit is likely the valve itself.
Nov 22, 2008 | Carrier SBP Humidifier
Humidifier
I have the evenflo cool mist humidifier, model # 758100. There should be a model number on the unit. As far as replacement filters, you can buy the Holmes humidifier filter, model # HWF62. It's compatible with Evenflo. I bought a 2-pk at Target for $15.99. Hope this helps.
Jan 09, 2008 | Evenflo Evaporative Cool Mist Humidifier
Carrier HUMCCSBP2412 HUMCASBP2412 Humidifier Filter Evaporator Furnace Pad 2-Pack Logo
Top Carrier Humidifiers Experts
Paul Carew
Mack Baxter
Tom Chichester
Are you a Carrier Humidifier Expert? Answer questions, earn points and help others
