Question about Tappan MEF500 Electric Kitchen Range
I have Tappan model TEF326FSA range and the oven and broiler will not work. The stove top works fine. What is the problem
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
breddi2
  • 126 Answers
SOURCE: Tappan electric range, brand new - top heats up
Call the manufacturer and ask them what to do, they can advise you as to what to expect when unit operates and possible cause. Most ranges on broiler will have some heat transfer to top, but this sounds extreme
Posted on Apr 26, 2009
heatman101
  • 43501 Answers
SOURCE: Oven/Broiler doesn't work. Stove top works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 07, 2010
Testimonial: "Thank you , this was very helpful. I thought that was the problem but didn't want to tear apart my stove before knowing for sure."
  • 1531 Answers
SOURCE: oven ignitor
is the ignitor getting white hot in the center.it may not be drawing enough current to open the gas flow regulator.the only othe thing foe you to replace is the main control board.or better known as the clock timer
Posted on Jun 09, 2010
marka19
  • 1430 Answers
SOURCE: My 2005 Tappan range is
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Nov 27, 2010
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan MEF500 Electric Kitchen Range Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
