Get following error. imaging unit seal tape check. tried reslotting the imaging unit it didnt help
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
JVC GR-DVM55U Error E06
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
Cannot reseat imaging unit in xerox phaser 6130 printer
You can find answers to your Xerox questions at www.xerox.com/support
Solution : Replace the Imaging Unit CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap.
Do not drop or shake the Imaging Unit after it has been removed from the printer as Toner spills can occur.
Do not expose the Imaging Unit to any light source for more than five minutes. Prolonged exposure to light may damage the unit. Cover the Imaging Unit with a light shield (such as a sheet of paper). Do not touch the shiny blue Transfer Belt.
  1. Power OFF the printer using the power switch located on the left side of the printer, toward the back. Press the power switch to the OFF (O) position.
  2. Press the button on the top right side of the printer to open the Front Cover.
  3. Locate the Imaging Unit, and then turn the four twist-locks to the left to unlock the unit.
  4. Grasp the Imaging Unit by its peach-colored pull-tabs on the top edge. Pull the unit forward and up, and then out of the printer.
  5. Place the used Imaging Unit in a bag and make sure the bag is properly sealed before discarding or recycling.
  6. Remove the new Imaging Unit from the shipping container and the sealed package.
    CAUTION: Do not remove the orange protective cover from the front of the unit until it has been installed in the printer. This will protect the Transfer Belt from being touched during installation.
  7. Place the Imaging Unit on a flat surface. Hold the unit firmly with one hand and with the other hand grasp the end tab of one sealing tape and pull the tape straight out, horizontally. Repeat for the remaining tapes; there are eight tapes in total. Make sure none of the tapes have broken. Discard of the tapes as normal office waste.
    NOTE: If any tape breaks off with the remainder inside the Imaging Unit, stop the installation and contact Support.
  8. Grasp the new Imaging Unit by its peach-colored pull-tabs on the top edge and install the unit in the printer. Make sure to insert the unit into the guides in the printer, and then push the unit all the way back into the printer.
  9. Turn the four twist-locks to the right, to lock the unit.
  10. Pull the orange protective cover out and then down from the top, center of the Imaging Unit.
  11. Close the Front Cover.
  12. Power ON (') the printer. A 'Ready to Print' message will be displayed on the Display Screen.
Nov 28, 2013 | Xerox Phaser 6200N Laser Printer
Heat sealer does not heat
Sorry to read about your problem, I hope this helps you out.
after you try to seal, open the unit..feel the white heat tape..check to feel if hot, if not..you have a defective unit....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
SC392
SC 392 Possible causes -
· Someone forgot to remove the toner seal of the PCU
· ID sensor defective
· TD sensor abnormal
· Drum does not turn
· Development roller does not turn
· Poor connection of the PCU
Regards,
Jun 11, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
ERROR 22
You Need to Try One Of The Following :
Remove and re-install Imaging Unit (make sure that Imaging Unit
is locked in place). Turn the printer off, then on.
Replace Imaging Unit (make sure that Imaging Unit is locked in
If problem persists for Error 30, clean the sensor.
If problem persists, check www2.tek.com/merlin/tko and/or
contact Service.
Dec 05, 2008 | Tektronix Phaser 740P Laser Printer
Neither deck will open to insert tapes in my dual deck vcr
It seems they didnt refirbish it, you should return it..
If for some reason you cant return it.
The problem is your carriage unit is damaged
The carriage unit is the parts that load the tape into the vcr
If you think you are able you can open it up and look if any springs have fallen out. If not then change the unit.
If you cant fix it your self a technician can easily do it for you since it isnt that hard and somplicated to repair, you just need good retainence
Dec 01, 2007 | JVC SR-V10U S-VHS VCR
SONY TSL-S9000L error message
Hi RIO,
I need a little more information to better assist you with your problem. What Operating System are you running and how old is this unit?
Is this the first time you are using this device?
Also look at the event viewer for info on the actual error, which could help to better explain what the problem might be.
--Roadhawk
Nov 24, 2007 | Sony TSL S9000L (TSL-S9000L) DAT Tape...
Panasonic NVGS4 camcorder problem
Did you try with different tapes? light turr sound is always there in Rew/FF as the tape rotatets very fast. If the head motor stops while spinning, the error will be detected and the unit needs resetting. also if the head is sticky, tape gets stuck on head and unit will stop. Try to clean the head with head cleaner and check.
Feb 27, 2007 | Panasonic NV-GS40 Mini DV Digital...
k24674
jasbo
jasbo
