Question about Honda Snowblower Working Light Kit Hs624, Hs724
Honda hs1132 snowblower wont move - Honda Snowblower Working Light Kit Hs624, Hs724
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
Honda engine snowblower wont stay running
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Dec 16, 2013 | Honda Carburetor for HS520 Snowblower
Snowblower wont start
Check out this YouTube Video. It will show you how to disassemble and clean the carb for the Honda HS520 snowblower.
http://www.youtube.com/watch?v=4i14aB6g798
Dec 04, 2013 | Honda Carburetor for HS520 Snowblower
2410 troy bilt snowblower wont start...no spark
unplug the switch to make sure it isnt just stuck in off position *(internally stuck while the switch will still move) If it starts you can unstick the switch with some WD and a couple back and forths with the key.
If you still have no spark you are gonna need a new coil.
Dec 31, 2012 | Garden
Broken choke control on snowblower
hi jared
the chokeis connect to the carb.it opens and close the trottle.try to locate where to connect the cable to opperate the trottle
bye
Jul 02, 2009 | Honda Garden
Sears 10inch gas snowblower wont move but runs
You may have a bad clutch assembly. Check it and then see if the belt is tight enough.
Jan 10, 2009 | Craftsman 4 Cycle Blower/Vac
Honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Dec 08, 2008 | Garden
Honda Snowblower Working Light Kit Hs624, Hs724 Logo
35 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
