Question about Go Ped GSR Sport Gas Powered City Scooter
My goped starts up fine, but after warm up it stalls and won't start back up
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
My 1988 buick century stall,s after driving. engine warm,s up.won,t start right after stalling.start,s after sitting 10 or 15 minutes
Possibly an ignition module or crank sensor problem. These are the two most common stalling electronics that will cause a stall when they get warm/hot and will then continue to operate once cooled down
Jul 12, 2015 | Buick Cars & Trucks
Piaggio fly 50 4t
Re-set the idle adjustment screw on carb? Also check fuel / air filter.
Mar 22, 2014 | 2012 Piaggio Fly 50 4V
89 K5 Blazer 350 TBI cranks but won't start... the rad hose blew, i fixed it then the next day it bogged and backfired, ran fine cold, but when warmed up it would lose power and stall when trying
Have you checked Google I found this hopefully it's not your timing or it may be flooded but doubtful have you tried spraying starting fluid into the intake while cranking it
Jun 01, 2012 | Cars & Trucks
Stalls when warm 95 camry
sound like your have the bad distributor, when you have trouble starting remove the distributor and have the auto part check it.
Nov 23, 2009 | 1995 Toyota Camry
1987 dodge omni will not start when it is cold
Adjust choke assembly. Good mechanic, 5-10 min.
Dec 15, 2008 | 1987 Dodge Omni
Go Ped GSR Sport Gas Powered City Scooter Logo
Top Go Ped Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Go Ped Toy Expert? Answer questions, earn points and help others
