Question about Games
SHOW ALL THE ***** - Games
When is the next United States Powerboat Show?
Unfortunately, you just missed this year's show - it was held on October 13th. Check out the following link to find info about this year's show and to learn more about next year's show when in becomes available:
http://www.usboat.com/us-powerboat-show/special-events
Oct 16, 2013 | Boating
Tip
Unable to open .PPS attachments directly from Windows Mail in Windows Vista
To resolve the issue, follow these steps:
For .PPS files (Microsoft PowerPoint Slideshow)
· Click Start, type regedit.exe and press ENTER
· Navigate to the following branch:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.11\shell\Show
· Right-click Show and click Rename
· Type the word Open so that Show is replaced by Open command
· If you have PowerPoint Viewer 2007 installed, repeat the above steps in this key, as well:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.12\shell\Show
· After changing Show to Open, close Registry Editor window.
For .PPT files (Microsoft PowerPoint Presentation)
HKEY_CLASSES_ROOT\PowerPointViewer.Show.11\shell\Show
HKEY_CLASSES_ROOT\PowerPointViewer.Show.12\shell\Show
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
Feb 23, 2011 | Microsoft PowerPoint 2010
My lacie harddisk doesn't show up in windows XP. Power is ok. Light is on and he makes normal operating noise like always. I have another one for which I use the same USB-chord and that one is working...
1. right click the my computer
2. go to properties
3. click hardware tab
4. and click Device Manager
5. show the Device Manager and click disk drives
6. your hard disk is show or not.
7. it's show then go my computer properties
8. select manage and show computer management window
9. then click disk management
10. your hard disk partitionis show right click the partition add driver letter (ex: h:, i: ..)
11. after open the my computer the partition is show
thankyou
Sep 15, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Need some basic show command to troubleshoot
mode exec user Router)
ping ip
show ip route
show version
traceroute ip
mode exec priveligiado
show arp
show interface
show protcols
show ip protocols
show startup-config
erase startup-config
reload
Jul 27, 2010 | Cisco ASA 5520 Firewall
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
May 30, 2010 | Panasonic AG-DV2000 Mini DV VCR
Need averatec laptop drivers
hi sir, you can download the drivers from the following links: i've given the driver name and link from which you can download the respective driver.
WIRELESS : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141788&brNum=3&show=0
AUDIO : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141789&brNum=3&show=0
VIDEO : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141792&brNum=3&show=0
MODEM : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141786&brNum=3&show=0
LAN : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141790&brNum=3&show=0
USB : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141791&brNum=3&show=0
AGP : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141785&brNum=3&show=0
TOUCHPAD : http://www.notebookera.com/ViewDownloadUrl.asp?ID=141787&brNum=3&show=0
kindly rate me.. thanks for using fixya..
Feb 12, 2010 | Averatec 3200 Notebook
Help me please!!
'version' will show the IOS version. 'show' will show all the cards and their status.
Jul 01, 2008 | Lucent APX 8000 Networking Switch
Games Logo
Top Games Experts
Lesley Cameron
Lesley Cameron
Pamela Leach
Pamela Leach
Are you a Game Expert? Answer questions, earn points and help others
