Question about Fantom Drives Databank 64gb Usb 2.0 Flash Drive
My pc will not recognize my 64gb databank fantom drive
All of a sudden is Write Protected
Is there a lock icon on the drive anywhere? If so, there is some kind of switch there that you need to move to unlocked.
Try right-clicking on the drive, select Properties and then look for a checkbox that locks the drive.
Try editing the registry:
http://ccm.net/faq/4214-remove-write-protection-from-a-usb-key-via-the-registry
Sep 01, 2015 | Fantom Drives Databank 64gb Usb 2.0 Flash...
How to remove the write protect on a fantom databank usb flash drive
Why would you try regedit on this? Depending on what files you are trying to delete you should be able to just right click on them and bring up the properties, once you do that you can change them or if you really want them gone just format the drive. Don't use safe mode for this just boot up the computer install the drive once the operating system sees it you should be able to change the properties using the above method.
Dec 12, 2012 | MicroNet New - Fantom Databank Fdb16u2 16...
My PC (or friends) doesn't recognise my Databank usb2.0 64GB flash
Try the stick in another device and report back if you can read and write to the stick on that device.
Plug other USB things into that port to see if the port is good.
Although rare, some USB things allow themselves to be inserted backwards.
Oct 19, 2012 | Watches
Fantom Hard Drive 112 GB is no longer recognized by Mac OS 9. On a Dell PC (Windows 7) it worked previously but now says that the parameter is not correct. The drive looks and sounds fine and did not...
if u have warranty u can use that ,................otherwise the repairer can only solve that problem,,,,..............or repair it,.............on half value,.........either u can purchase new one,...........ok buddy..............
enjoy
Dec 05, 2009 | Fantom Drives 120 GB Hard Drive
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
Fantom external drive 1T runs but not recognized
are u using the usb cable for connecting the drive? use usb ver2.0.
May 17, 2009 | Computers & Internet
My pc and mac computer do not recorgnise my fantom drives
Hi, Mac uses a certain file system that windows does recognize the best thing i would suggest is mount it back to you mac and copy all the date to your mac then format the hard disk with windows ntfs files system. now u will be able to use it on both.
Cheers
Apr 27, 2009 | Fantom Titanium Hard Drive
Fantom Drive problem
Try connecting it to a Windows XP Pro pc. Right click on "My Computer", left click on "Manage". Once the new management console opens, left click on "Disk Management". If the USB drive is recognized by the pc, you will be able to right click on it, and select "Delete Partition". WARNING: YOU ARE DELETING EVERYTHING ON THE DRIVE! Once it's done, right click on the drive again, and select "Create New Partition". Proceed thru the wizard that pops up, and format it. You will have a choice of using FAT32, but, if the partition is larger than 32 GB, it will fail (it's a Windoze limitation), so NTFS is your only choice, unless you use a 3rd party utility, Win98 (supports huge FAT32 partitions, 4 TB, I think), or Linux.(preferred). Good Luck, hopefully everything will work out fine. T-Power
Apr 01, 2008 | Fantom Titanium Hard Drive
Problem with my PC recognizing my external hard drive
If you know the files are there and the drive cannot be read then there must be a read error, the only other thing to try is a different usb or firewire port as the port itself may not be reading the drive. Try it first by putting in a different port while the pc is on then plugging in and then restarting if the device is not recognised. You may also try the drive in a friends pc to see if it is port trouble and not the drive
Apr 28, 2007 | Fantom Drives 120 GB Hard Drive
Fantom Drives Databank 64gb Usb 2.0 Flash Drive Logo
44 people viewed this question
Top Fantom Drives Computers & Internet Experts
micky dee
fixya62589
Terry Hair
Are you a Fantom Drives Computer and Internet Expert? Answer questions, earn points and help others
