Question about Honda Eu3000is Eu3000 Generator Service Repair Manual 61zt700e6
No ac current coming from my honda eu3000is generator
2 Suggested Answers
  • 10 Answers
SOURCE: honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
Posted on May 31, 2012
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
My honda generator is sending high ac voltage
adjust the engine rpms to drop the voltage
replace the voltage regulator
Honda eu3000is generator surges
May 31, 2012 | Honda Eu3000is
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
I have a eu3000is. It's only 3 years old and has
Hi there .
All the Honda generators have 2 years full warranty (parts and labor) . Just check with your Honda dealer and make sure they call Honda tech support before any decision or you can call customer support @ 770-497-6400
and see if they can get warranty for your machine .
Hope this help.
Sep 08, 2009 | Electrical Supplies
Need a battery for honda eu3000is
New battery for Honda eu3000is can be found on amazon. take a look here Charge your devices with guaranteed safety and chose the best one. P.S. watch out on seller reviews. I hope this was helpful. cheers
Mar 28, 2009 | Honda 3000 Watt Portable Generator
Honda eu3000is won't start with starter.
replace the 20 amp fuse that is inline to the starter. you will find it wired in above the battery.
Mar 01, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda Eu3000is Eu3000 Generator Service Repair Manual 61zt700e6 Logo
96 people viewed this question
Top Honda Electronics - Others Experts
Bill Boyd
Richard Warren
Richard Warren
Clive
Clive
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
