Question about HP PSC 2410 All-In-One InkJet Printer
Clicking noise and will not print.
When powered on, hourglass does not disapper and hear a clicking noise. This happened after I carried the printer to a different room in the house.
  • eo1234 May 21, 2009
    same problem after disconnecting the power cord and reconnecting. the problem seems to be from the scanner, but in all the links you added i didn't find any solution for the problem (just how to identify it...)
    do i have to go to HP service center?
Hi Folks
My 2410 had the same problem and is now 100% functional again
Here is the Solution:
Go to hp.com
at search look for exactly:
!psc 2410 how to clean the scanner"
the first hit is the right one.
There is a complete description, how to do.
The problem seems to be, that the scanner can't calibrate on the right optical marker (inner backsite of the scanner glas) and the motor still retries to move the scanner behind this marker what causes the noise.
Hope it willhelp you
regards,
Michael
Posted on May 22, 2009
    President:
  • HP Master
  • 1,996 Answers
Please have a look at this link and this link and follow the instructions to determine if the sound is coming from the scanner or print cartridge.
If required, here is a link to cleaning the printer.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 20, 2009
  • efs_perpends
    efs_perpends May 22, 2009
    Here's the link for cleaning the scanner, but this is not recommended if you're under warranty.
    You also have the option, whether under warranty or not, to contact HP tech support, and in this case that is my recommendation for your problem...link to that page here.
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Washing machine makes clicking noise after filling up and wont spin. Kepps on clicking until i force shutdown, which then drains the water away.
hi, the problem you have is the motor carbons (brushes) have worn down ( which is natural if machine is used every day ). the machine fills up with water but there is no motor action. the clicking noise you are hearing is the relay on the pcb sending a signal to the motor to turn, but with the carbons worn, there is no motor action. Easy enough to replace them. UNPLUG machine before any repairs are carried out.
Dec 19, 2013 | Indesit Washing Machines
Tv won't turn on makes clicking noise
that click is the power relay, but i have seen several diferent ways this can happen, is it clicking so fast it kinda resembles a buzz noise or do you just hear one loud click when you turn it on? email me maxtek73@yahoo.com.
Sep 08, 2013 | RCA P52960 52" Rear Projection Television
My Chevy Equinox 2005 is making a noise when I turn left or right. the noise comes from the front wheels. I was trying to find where to put power steering fluid, which I could not find. What should I do?
depends on the noise , I know that sounds silly, but it works,, is the noise your hearing a clicking sound as you turn? if so, its the CV axles going out ,, From your info I don't know if you have the all wheel drive or just the front wheel drive, but if you hear clicking, its CV joints going bad, Now if what your hearing is a squealing noise, that would be the power steering pump, look at where your fan belt is and what all it drives,, one of those will be your power steering pump, some models have the fill tube for them right on the unit itself, and others have a off pump location for filling, however your year happens to be the a first generation and they used electronic power steering, and naturally you need to have it dealer checked
Sep 09, 2011 | 2006 Chevrolet Equinox
Clicking Noise similar to turn signal
sounds like a bad turn signal relay
Sep 09, 2009 | 2001 Chevrolet Malibu
When I turn on my 2410 printer the hourglass stays on endlessly.
try uninstalling and reinstalling
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
582 people viewed this question
Seeker5211
Seeker5211
