Question about Baby Gear
I need to put the harness back together-have all parts but....
  • 355 Answers
Can you give me more details bout your problem
Posted on May 20, 2009
Cant find a harness to plug into the back of a Dual XD250 RADIO.
You won't ever. They make a universal harness. You should have a wire harness for your new radio only that was included with the radio. It should plug into the new radio and the other end will just be wires. Then you will need to go to a parts store, ( AutoZone, Oreilly's, Advance Auto, Etc) and but a radio wire harness for your truck. It will have a connector or two that plug into the harness that plugs into the back of your stock radio and the other end will be just wires. you will then connect the two harnesses together by matching wire color. ( EG: Purple to Purple, Gray with black stripe to Gray with black stripe, etc)
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Car Audio & Video
Tip
How to install Radio in Honda Accord
Things You'll Need:
* Stereo
* Wiring harness
* Dash kit
* Phillips screwdriver
* Heat shrink
* Lighter
* Wire strippers
* Wire caps
In order to install A Radio first follow steps of Removing the Factory Radio
#1
Open the center console, and you'll see two phillips screws at the bottom. Unscrew both of them.
#2
Remove the drink tray, and unscrew three more phillips screws. The center console is now loose enough to move.
#3
Pull the center console back a few inches to expose two more screws under the plastic part of the gear shift. Remove these screws.
#4
Pull the ashtray out of the dash, and you'll see one more phillips screw. Remove this screw and pull off the plastic panel around the factory stereo.
#5
Locate the metal tray under the factory pocket (below the stereo), and pull it out of the dash. There will be two phillips screws holding it in place; remove those, and then pull the stereo out of the dash. You'll need to unplug the wiring harness that is plugged into the back of the radio.
Now Install The New Stereo
#1
Assemble the dash kit, as shown in the instructions. Put it into the dash where you just took the stereo out. There will be a rectangular opening, and a pocket underneath. The opening is where the radio will go.
#2
Secure the dash kit by screwing in the one screw in the ash tray, and the two in the opening of the panel.
#3
Insert the metal cage that came with the stereo into the opening above the pocket. Ensure that the fit is flush with the pocket. Using a screwdriver, bend the metal tabs upward, which holds the metal cage in place.
#4
Start wiring the stereo harness to the wiring harness. Match wires color by color until all of the wires are paired. For example, if you find a purple wire coming out of the aftermarket wiring harness, plug it into a purple wire from the factory harness. You aren't touching any of the wires in your dash on this step, you are simply wiring the new stereo to the wiring harness.
To connect these wires you'll want to place a piece of heat shrink over one of the wires, strip the ends, twist both ends together, and then pull the heat shrink over the exposed metal parts of the two wires. Heat the heat shrink with a lighter until it shrinks and forms a tight bond between the two wires. When done correctly, you won't be able to pull the wires apart.
#5
Plug the aftermarket harness into the factory plug, and insert the radio back into the dash. If you find wires that don't have a match, be sure to cap them so that the ends aren't exposed. Exposed wires are what cause shorts and electrical problems.
#6
Work in reverse order to put the dash back together. The radio won't be secure in the dash until the dash is put back together.
Hope this helps
Thanks
on Oct 07, 2010 | Honda Accord Cars & Trucks
I took my car seat apart to wash it and I don't know how to put it back together
We would advise you contact the manufacturer of the carseat as the likelihood is that the unit will need to be sent to specialist engineers to inspect and put back together correctly. Due to safety implications of the harness being incorrectly fitted it may not be possible to do this yourself.
Dec 19, 2012 | Baby Gear
Need instructions to put harness in carseat back together
my mom has an eddie bauer carseat for my daughter and washed it how do you put it back together
May 24, 2009 | Eddie Bauer Baby Gear
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
How do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Apr 20, 2009 | Britax Eclipse Si - Paris Convertible Car...
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
2001 Chrysler Town & Country Sliding Door Harness
you need to remove the old harness and open it up then repair the broken wires this will save the old harness and what the other people are talking about
Nov 12, 2008 | 2006 Chrysler Town & Country
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
