Question about Autel Maxiscan Ms309 Obdii Code Reader Obd2 Eobd2 Obdii Eobdii
Maxiscan ms309 blank screen
Plug it in, lights up, no wording
My 2001 mercury villager check engine light comes on. I use maxiscan ms309 to scan. found 2 code but no code show. it says "code not found in module. Try again and say the same thing.
Not sure, but you may need a more sophisticated scanner that will also report special codes that for instance the transmission module communicates to the powertrain control module (PCM- the main computer on the vehicle, but nowadays there are also computers on several other systems, like the transmission and the chassis electrical system, and the ABS system. They all communicate with the PCM. I thought all codes were available from the PCM, but maybe not in your case.
Anyway, if you have a friend with a more high-end scanner, try scanning it again. Or try at Autozone, and see what their free scan says.
Sep 16, 2017 | Mercury Villager Cars & Trucks
How to access trouble code
year vehicle manufactured? if 1996 & later, OBDII scanner to be plugged into a port (typically, should be near the steering column, under the dash).
older models may have OBDI (no standard location of port) scanner specific to the make of the vehicle. search the web, on how to read manually (or without scanner) the code by counting the number of blinks of the MIL (malfunction Indicator light) (aka check engine, or service engine soon).
Autel MaxiScan MS309 OBD II Code Reader Scan Tool
Oct 15, 2015 | Suzuki Vitara Cars & Trucks
I need to reboot my Asus, the screen is totally blank from switch on, F9 is not doing anything. Help pls
Can you see anything at all? Lights sounds etc? Shine a light on the screen and look for words. If you see anything it is most likely the back light inverter that is bad.
Aug 01, 2014 | Computers & Internet
Abs light came on and is staying on what could be some problems to look for
There are products out there, available to consumers, such as the maxiscan MS309 OBDII/EOBD unit. It plugs into your automobile computer and reads, and can reset false problems. You must make sure that the unit you buy covers the type of auto you own. The connection point in my Ford is in the fuse box.
Jul 12, 2014 | Cars & Trucks
I hav a Toshiba Satellite Pro L300 for about a year ++, recently when i plug in the power supply, the screen would turn blank white, no words or symbols jus blank screen. However i am able to use it wif no...
thats a wierd one, it could be a short in the power connecter but i gots no idea how that would mess with the screen, try pluggin it in without the battery that will help to figure out whats wrong
Jan 17, 2011 | Computers & Internet
My screen is blank wont come up with words
Sounds like the ipod may be dead. When you plug it into the computer does it stay blank, nothing ever comes up on the screen?
Jun 25, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Blank screen with word "in line" cant change channel or anything
maybe try to change the input source. plug in cable or a dvd player and see if anything else works or generates output or at least a signal? Go to menu and see if you can configure it any differently? hit me up if that doesnt help
May 25, 2009 | Toshiba Televison & Video
Nintendo 64 problem
Same problem with mine, i figured out that if certain parts inside the n64 are damaged or worn, it will affect the display of the game
Aug 03, 2008 | Nintendo 64 Console
Autel Maxiscan Ms309 Obdii Code Reader Obd2 Eobd2 Obdii Eobdii Logo
485 people viewed this question
Top Autel Computers & Internet Experts
David Payne
David Payne
Are you an Autel Computer and Internet Expert? Answer questions, earn points and help others
