Question about Ovens
Teka htd 720 stopped working - Ovens
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
Instruction manual needed for teka oven profesional 518
http://uk.search.yahoo.com/r/_ylt=A7x9QV_W9RdP1TwAyj5LBQx.;_ylu=X3oDMTBybWpoN25zBHNlYwNzcgRwb3MDMgRjb2xvA2lyZAR2dGlkAw--/SIG=12dh9vsl5/EXP=1326999126/**http%3a//kitchen.manualsonline.com/manuals/device/oven.html
Jan 19, 2012 | Ovens
I have a Teka oven HI-595 that shows power, fan works and grill works but oven won't heat up. What should I do?
If the fan is working o/k, then it is probably the oven element that is faulty, usually located at the rear of the oven compartment behind a removeable cov er.
Oct 21, 2010 | Ovens
Oven overheating ,even on very low degrees. Its a Teka
In most cases of ovens overheating, it is usually due to the oven thermostat being faulty.
The usual solution is to replace the thermostat.
Mar 10, 2010 | Ovens
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 | Ovens
Teka Model HC-595 - oven does not heat, fan working ok grill working ok
Sounds like the fan element has blown. I think access is from inside the oven at the back BUT the screws to undo the element are accessed by removing the rear cover. You will have to take the oven out of the cabinet to where is is fitted to do this and from memory there is an earth tag which is fixed to one of these screws
Oct 19, 2009 | Ovens
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
