Question about Riccar 8955 Upright Vacuum
Lost suction after I changed the bag and cleaned the air filter
My Riccar lost suction power after I changed the bag and cleaned the air filter. It worked great before I did that. It is an older upright model.
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
Posted on May 21, 2009
  • David Sucher Jun 06, 2013
    All fixed, was the cover. Thank you
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
Full bag light is on with a new bag
There is a clog somewhere in one of your tubes and/or the filters need replaced
Jan 04, 2014 | Riccar Vacuums
No suction in hose
There is most likely something stuck in the hose.
Jun 06, 2013 | Riccar Model RC1100 Canister Vacuum...
My henry vacuum has lost suction and there's no blockage in the pipe.
Suction cannot be lost if the motor is running normally unless the air flow has been interupted. Lift out and clean the filter so air can flow through, replace the bag, unscrew the flexi hose at his "nose", and also remove from the steel pipes. Finally drop a
Sep 28, 2010 | Henry Vacuums
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Riccar 8955 Upright Vacuum Logo
297 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
