Question about Bosch NET9652UC 36 in. Electric Cooktop
Error 42 on Bosch cooktop NET 9652UC
Flashing er42 How do I fix?
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: error code er26 & er42 for a bosch cooktop
Do this and follow the common sense. God bless you
Lower motorized latch will not lock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring. 1. Check P24 connector on the power board.
2. Ensure door latch switches are operating properly.
3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
4. Check P10 connector and check if latch motor wire pinched to the appliance chassis.
5. If F42 persists, replace power board.
Posted on Sep 25, 2012
SOURCE: net7552uc bosch cooktop error codes 26 and 42
This may be malfunction of the main electronic board.http://www.ifixit.com/Wiki/Edit/Bosch_NET7452UC_cooktop
Posted on Oct 07, 2012
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
Feb 20, 2013 | Bosch 30 in. NET7452UC Electric Cooktop
Bosch cooktop net 7552uc parts
http://www.bosch-home.co.uk/store/spareparts/search
Feb 07, 2013 | Bosch Cooktops
Error code er26 & er42 for a bosch cooktop
Sep 25, 2012 | Bosch Cooktops
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
My bosch gas top spark lighter doesn't work on any burner...how do I fix it?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 21, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Boch ceran 9000179011 try to turn on and red light flashes on right hand side of touch controls
Did you ever get a solution to this? My Bosch hob is doing the same wanted to know how to resolve or if I need to call out a technician.
thanks.
Sep 13, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
Bosch NET9652UC 36 in. Electric Cooktop Logo
124 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
