Home | Whirlpool | 75 Pint Per Day Dehumidifier: Largest Cap... | Unit is repeatedly fre...
Whirlpool 75 Pint Per Day Dehumidifier: Largest Capacity in the industry Dehumidifier
Problem for Whirlpool 75 Pint Per Day Dehumidifier: Largest Capacity...
Unit is repeatedly freezing up
By cpbrockwell on May 20, 2009
Whirlpool AD75USTO dehumidfier. I use a drainage hose, but noticed that nothing was coming out. The hose was flushed and the filter cleaned, but still no water production even with the hose disconnected. This unit is less than 2 years old. The fan is running constantly, but I get ice formed on the right side of the unit. Apparently, the coils are freezing rather than emptying water either into the bucket or drainage hose.
Best Solution
posted on May 20, 2009
Helpful)
MNTECH
Rank: Guru  Whirlpool Expert
Rating: 94%, 854 votes
Almost all dehumidifiers now have automatic defrost, but if you are seeing frost is just one small area, it means there is a refrigerant leak. Check your warranty to see if the sealed system is covered longer than one year. Generally, if it is, most manufacturers will replace the unit (rather than repair it, as the repair is rather expensive compared to the cost of a new unit). If you do not have any sealed system warranty coverage left on it, don't fix it. Buy a new dehumidifier.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Whirlpool 75 Pint Per Day
Questions and Unsolved Problems for Whirlpool 75 Pint Per Day
Do you recommend Whirlpool 75 Pint Per Day Dehumidifier: Largest Capacity in the industry Dehumidifier?
Answer
Answer
how do I put the drain in a zenith zd30
Answer
Whirlpool AD75USTO dehumidfier. I use a drainage hose, but noticed that nothing was coming out. ... (More)
Answer
Dehumidifier will not go on empty bucket light will not go off
Answer
have brand new ad75usto, bucket is in and hose hooked up. Bucket fills up and full light comes on.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool 75 Pint Per Day...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
