Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Plate glass broken
The glass on my Canon MF8180c broke during a move interstate. Is it an easy task to replace?
    Genius:
  • 1,011 Answers
My concern is that if this unit took a hard enough bang to bust the glass, what else suffered?
Did you transport the printer yourself or did a moving company do the work? If you moved it, take it to a Canon authorized repair center and get an estimate. If a moving company transported the unit, contact them and place an insurance claim on the damage. By law, the moving companies are required to carry damage insurance.
Posted on May 20, 2009
Tip
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 | Ovens
Broken glass
Yes, although it's not cheap nor easy to replace. ifixit.com
Nov 18, 2013 | Tablets & eReaders
Since upgrading to windows 7 the canon mf8180 printer is working but I can no longer use the USB connected scanner.
The Canon 8180 will work with Windows 7 32 bit operating systems only. Their latest ToolBox drivers will also get the USB connected scanner to function. 64 bit Windows 7 users are simply out of luck as the printer is not compatible. Drivers are on Canon's site and easy to access.
Dec 29, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
My Canon imageCLASS MF8180C has streaks when it prints and does copies. How can I fix this?
Does this problem appears when you use the page feeder? Yes, then you have to clean the platen glass using a cloth dampened with water. See upside of your printer for more information.
Aug 04, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
My kenmore elite top load washer was rinning perfect til it got dropped 8 inches during a move now the whole tub seems loose and it wont balance when the spin cycle is on Help
Your support plate under tub above gearcase was knocked out of place, lean washer back and try to adjust plate back in place were it is sitting back on the glides. This is not an easy task bu it can be done,sometimes it is best to call a repairman to do the repair so he can check if there is any more damage.
Dec 22, 2009 | Kenmore Washing Machines
Canon MF8180c I need solutions for E100
E100 scanner fault
Check the connector of the laser scanner assembly.
Replace the laser scanner assembly.
Replace the DCNT Borad.
Dec 02, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I have a 2007 Honda Odyssey and broke the passenger side mirror. It is still attached and the power still works to move the mirror. But the glass is cracked. Where can I purchase, just the glass mirror...
If you go to a parts house, they can order you a mirror face for around 10 to 15 dollars. It simply sticks to the mirror that is broken with adhesive. It is very permanent and if the mirror is still working and in tact mostly (only broken glass part) it should fix you right up. Look at autozone, oreillys, or even JC Whitney or Pep Boys for example. Been there Done that! :-)Hope that helps.. Thanks!
mrstan
Aug 31, 2009 | 2007 Honda Odyssey
Passenger Side Mirror Glass Discoloring on Bottom Edge
Hi,welcome to fix ya. this is pretty easy heres how click here be sure to heat the glass with a blow dryer first to soften the tabs on the glass . If there is anything else I can help you with let me know .
Apr 01, 2009 | 2004 Acura TL
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
71 people viewed this question
old marine
old marine
